A story of mysterious interaction between a diy tda1543 dac setup and the human body.
Yeah that's the circuit I was thinking of. Pin5 can be 8V with TDA1543, on TDA1387 you'll likely destroy the chip. If using 8V on 1543, you'll want the TL431 to set a higher voltage, about 6V.
For 16X parallel it would work too, just lower the 1k1 suitably to cope with 16*2.3mA for the current swing.
It seems to me the TDA1543 is indestructible :D
Once I placed it in the socket wrong way and left it sucking 1A for minutes. Checked the temperature and got a blister. Worked perfectly afterwards! :D
(1K1 ÷ 16 should do...)
I'll try this circuit and let you know asap. Thanks!
Hello Abraxalito,
I've built the circuit you suggested.
("Single PNP transistor in common-base mode. DAC output goes to emitter, I/V resistor between collector and 0V." for TDA1543)
It sounds divine !! Much better than the single TDA1543 or 24x TDA1543 with Output resistance to ground. Really appreciated the tip !
I'm only having this little trouble: It played fine for a few minutes, then there was a pop and it when virtually quiet. After testing for everything else I figured maybe there was trouble with the BC807. I replaced it and it played fine again! After a few mintes it went quiet again. :D (Attached are the components I'm using; After Ferrite Bead we have a healthy +3.79V)
What am I doing wrong ?
How are you generating the reference voltage to feed to the bases?
Its possible you've got oscillation - try putting 220ohm resistors between the Vref and the base of each transistor. I think my original schematic had a ferrite bead on the base but that's not enough to suppress oscillation in every condition.
Yes, bottom left is the TL431 !
Meanwhile I've added the second channel (it's a bit neater) :)
Here's a few pictures of the complete setup, with "plug ins" next to their seat.
(the two extra 8 pin holders are for components that are not in use)
The TDA1543 is under the little alluminum heatsink. I use this board also for the 24x.
( Waiting to buy BC807s :D )
Hello Abraxalito,
please correct me if have misunderstood you: I've added two 220ohms between Vref ( TDA1543's pin7 ) and each transistor's base (BC807), next to the ferrite bead.
Something is not right though: all is silent, the circuit's consumption (including the TDA1543) rises from 0.04A to 0.10A and the +3.8V at the (transistor's) base drops to 2.9V. If I remove the 2 resistances, it plays fine, but I keep it short not to burn the transistors again :D
B.
Ps here's the player if you want a closer look.
What SD card are you using with that SD player - I suspect that might be your problem - it requires a fast HC SD card
"Only supports a subdirectory, only supports 32GB of memory card (memory card must be CLASS6 and above, must be a HC card)."
I know 2 people who have this same SD player & no static although clicks & pops if a slow SD card i sused
Did you leave the ferrite bead in circuit? What my intention was for you to replace the ferrite with the 220R resistor. I can't see why adding the resistors in parallel with the bead would change anything at all. So you're right, something's definitely not right. Power consumption of 100mA is also not at all right. With the TL431 voltage dropping it tends to indicate you didn't connect the resistor in parallel with the bead, rather it went some place else...
BTW, Bart, do you have a link where you bought on ebay - I see it comes with remote control but I don't see that remote with any other offerings?
I just want to get the IR codes sent for each of the buttons: up, down, left, right & play/stop. You don;t happen to have an IR learning device, do you?
