Hagerman Bugle 2
Joined 2009
Does anyone has an idea if it´s worthwhile to change the TLE2426 to a package type with Noise Reduction Pin?
The ouput noise voltage will drop from 120µV to 30µV and the line ripple rejection is improved.
A small adapter could handle this like on the attached picture.
  • tle2426.pdf
I know this is an ancient thread - simply answering in case someone is contemplating to order the Bugle from Europe. I ordered a Bugle 3 recently and it arrived roughly within one week (was not home, so cannot tell exactly). Should've gotten a kit - more fun building it.
My Bugle is breaking in now. I can already say that record noise is significantly lower compared to other phonos I used.
Great to hear, nb.
BTW, I believe Jim Hagerman no longer offers kits - only fully made up products.
I have heard the Cornet 3, too - that's a damn fine phono stage, as well. :)
Andy
Andy, it looks at if Jim's at least still selling PCBs, so people might have to to order parts by themselves. Did you have a chance to compare the Bugle and the Cornet?
I have been thinking about the Cornet as well, but then I would need an additional sut or pre-pre, so not sure it is woth the effort. I have a MC cartridge but only used my phono stage mc input until now.
Nik
Nik
Aah, I didn't know that, Nik. I emailed Jim last year about a kit (forget which one it was) and he responded by saying that he had given up selling DIY stuff.
A mate of mine has both - although his Bugle only has MM gain. So we were able to directly compare Bugle with Cornet 2 - and the Cornet sounds better!
Now, Jim sells the Cornet 3 - I've compared this to the Cornet 2 and it sounds the same ... but is quieter! :)
Sure, with your MC, you will have to use a SUT - or, better IMO, a 'head amp' - with a Cornet.
Andy
I think that your Bugle was fully broken-in long before the first LP was finished playing.
6L6
Moderator
Joined 2010
Anyway I am also thinking of getting the Bugle 2 board, but I will need MM & MC, is this possible from the one board.:confused:
The Bugle 3 is different from the 2 in this - " It improves on the Bugle2 by adding small internal switches to select various Gain and Loading options, easily accommodating any MM or MC cartridge."
Bugle3 - Phono Preamp MM/MC – Hagerman Audio Labs
You could add some switches to the 2, or some header pins as I did in the guide - honestly, how often are you switching cartridges?
