Why Let an Amplifier Sound Good when You can Force it to?
stocktrader200 said:
Unity gain stable ( 100% NF ) is one of the must haves in any amp I listen to.
It alludes to fantastic stability.
Achieving something which is unnecessary (unity gain stability in an amp not used for unity gain) almost always means losing something else, which may be necessary. You might compromise slew rate, noise etc. Overengineering is almost always poor engineering.
Wavewhipper might like to do some reading about common-mode distortion, which can be introduced when the input signal and feedback are not summed at a single point but at two inputs to a single stage (e.g. two bases of a BJT LTP, grid and cathode of a valve stage). Common-mode distortion cannot be removed by feedback. It is something to be considered, but it is usually small - so small that many designers seem to get away with not even being aware of it.
Yes, but I have seen very nearly that plan in several old-old transistor amps.
Comparator? 20mV input will swing the output, 60mV will slam it. That's poor for a comparator. In most audio we have signals up near 1V, and yes it will "comparator" all the medium and loud parts to bent square waves. You even find this done in guitar distortion. (Usually one such stage is not enough for that.) This hyper-sensitivity, and *high* THD even before clipping, is the main problem.
It works fairly well as a mike preamp for dictation speech through a dynamic mike; all those $13 mono cassette recorders (and the low-price 3" reel-reel machines before them). Input levels rarely exceeded 1mV, distortion was tolerated, exact gain was moot because all $0.50 mikes and all talkers vary a lot in level.
I believe at least one Moving Coil phono head uses essentially this AC condition. Signal levels are tiny, so THD is tiny. Stage load is 47K so a 4.69K Zout is fine. Source is 10-100r so a 2K-4K Zin is fine. Temps around a phono are usually benign.
I don't follow the gain vs temp complaint. Yes, in a Military -50C to +100C environment the gain will swing like +/-25%. But this is an audio forum, primarily domestic audio, mostly in living rooms. +/-15C, 10C to 40C, is extreme for most of us listeners. I keep my rooms to +/-3C. The gain change is more like 1%, inaudible. (This stage as shown will not self-heat enuff to matter.)
Output impedance can be whatever, as long as it is not too high and you know what to expect. High Zout can sometimes simplify interstage networks. Here Zout is 99% controlled by the resistor tolerance.
Input impedance does go directly as hFE (and ESR only if the cap is crappy; it often was). However if you cascade such stages the low-hFE units suck more against the high Zout stage before it and voltage gain variation is lessened. (It is often better to design such things on current gain rather than the now-customary voltage gain.)
Zin and input overload level can be increased with a simple series resistor. This is an interesting form but tends to hiss.
"Is this feedback?" There's feedback in it, but not so you can design with it, and not so you can get "good" performance in most audio applications.
In a -50C to 100C environment gain of a 2N3904 can swing from 150 to 400, this is +/-63%, +/-4.2dB.
In the old days transistors were expensive (like 10~100 resistors), incidentally object of cult too, but a single transistor was better than nothing. ICs were even more expensive (like 10~100 transistors), and harsh at zero cross in audio circuits (this is the worst place to have a discontinuity!!) Designers were trying to make consumer equipment with whatever was available and affordable, to cover the needs of a society growing in size and complexity. It was 2nd generation equipment. Previous sound recorder approach was registering vibration mechanically in cylinders or discs. Figure out what gain accuracy did that have.
Imagine a recorder without AGC and with +/-25% (or more) gain change depending on weather, and taking one or more minutes to settle upon power up. Now imagine yourself trying to gather evidence to prove a crime with such a recorder (such that the voice of the criminal has to be recognized by a jury), or trying to record something in nature in extreme hot or cold conditions, or noise analysis in a factory to catch a problem. These circuits were abandoned for several reasons. A dedicated operator was required to continuously compensate the flaws of the machine.
In the end price leveled out, so in SMD it costs about the same to place a resistor, a MMDT3904 (dual NPN) or a LM358 (dual cheap op-amp), with part cost being almost negligible for the resistor and comparable to placement cots for the MMDT and the LM358. All values around 10 cents.
The environmental conditions for using single transistor stages are no longer met. What remains? Cult to something that original designers were not giving cult to? The appearance? Cult to appearance can govern human tastes when environmental conditions are not opposing, but this is a side effect of seduction. Humans not under seduction are not vulnerable to cult to appearance.
I remember looking at an LM723 series pass power supply of a few hundred watts and figured I could make it function as an audio power amp by tapping in at a Vref input.
It would have been a Class A amp and who knows what bandwidth as it was designed.
If a DC audio amp were modified for bipolar adjustable power supply duty, the power rating would need a good bit of de-rating. They are meant for pulse duty.
I recently forced an amp with unbalanced output transistors, I forced it to sound good with negative feedback. The amp didn't tell me what components to use, I showed that amp that it will accept the components I made it with, forced it to work, and I like that.
Yes I'm beginning to like that very much.
There are limits imposed by physics on how much OLG can be obtained. Each gain device introduces phase shift and propagation delay.
The following rule of thumb applies: OLG*UGF/NGD=nearly_constant
OLG=open-loop gain
UGF=unity gain frequency
NGD=number of gain devices, cost
So cost is roughly proportional to gain bandwidth product (cost ~=GBW=OLG*UGF).
In practice it is more convenient to consider how much GBW can be obtained from a fixed number of stages (considering other constraints), as a design problem with wider scope is difficult to close.
However, when the distortion originates from self disturbance within the loop, such as capacitive or inductive coupling, or summing node non-linearity, increased OLG does not reduce THD (not proportionally):
- The magnitude of the error (drive) signal becomes reduced by the same amount of dB the open loop gain is increased.
- The magnitude of disturbance signal, relative to error signal, increases by same amount of dB (for 1st stage, progressively less for intermediate stages).
- Thus, past some point, X more dB of open loop gain result in: X more dB of open loop distortion, attenuated by X more dB of NFB gain.
So additionally: there is an optimum range in the number of stages, more stages would not allow to reduce THD arbitrarily, as non-NFB-correctable sources of THD become dominant.
The optimum number of stages for a class AB audio amplifier is between 4 and 6. Less than 4 stages: more HF THD. More than 6 stages: no improvement in HF THD.
THD sources not correctable by NFB:
- In class AB amplifiers: Distorted inductive coupling from: halves of output current waveform flowing through different inductive paths. Inductive coupling from distorted base current waveform. Inductive coupling from base current switching peaks at current waveform zero cross.
- In BJT transistor stages with miller capacitor: Logarithmic nature of Vbe=log(Ic).
The field where this knowledge is obtained is multi-channel class D, when the analog audio guru learns RF.
Attached picture shows a 50ppm THD @ 50W class D minimalist balanced modulator with single integrator, "a piece of analog audio electronics". NFB at 20khz is around 38dB. Open loop THD is below 1% typically. The limiting factor is: about 20dB stronger magnetic fields than in class AB, permanent magnetic fields at any volume, square wave and periodic glitches in nature.
But there is a technique to bury the THD of inter-channel disturbance under the THD of the own channel, and under noise floor at low volume (about 120dB-A). The SO-8 is balanced comparator. The SO-14 is quad op-amp.
I will be interested in making first order and/or even order distortion since it's a bass amp experiment. I already have an Ampeg and Marshall amp but thought I'd mess around with one and see what happens. Well, EYE can't hear so I mean hear what happens.
That isn't tossed at you Eva LOL.
Disabled Account
Joined 2015
A question.
If a high OLG resulting in a lot of negative feedback is so good, why does almost every good commercial power amplifier use to have a fairly low amount of NFB?
Furthermore, cheaper amps use to have higher NFB ( typical ~50db ) than expensive amps. A typical figure among audiophile amps use to be 0 to 30db.
Can the reason be that amplifiers that are forced to sound good by the means of NFB tend to be a bit grumpy and will output a slight squeak of objections?
Low NFB amps are glad and natural and will make their owners glad.
Disabled Account
Joined 2015
Marcel, do you really think that mistake has biased an entire industry for several decades? We humans are stupid but not that stupid.
If there is smoke there usually is fire.
But I never get tired of this issue since it's probably the one factor that's dividing audio people.
I see a clear pattern:
Low NFB, simple designs, single ended class A in one end.
Complex amplifiers with a lot of NFB in the other.
I think the position in that gliding scale tells something about who you are.
The former; poeple who thinks subjective impressions are more important than objective data.
The latter; rationalists.
But I think Diyaudio has a light problem since the audiophiles usually goes to the Passlabs section, so the rationalists has to dwell here in the "solid state" section. So the "inbetween" people really don't have anywhere to go.
The question should be. Why do some people like excessive amounts of distortion?
Bass and guitar amps are perceived as twice as loud with some even and second order harmonics. Most people think they sound better. Funny, at proper levels
of distortion the distortion isn't heard, but only a pleasant tone and much louder sonic output. Lots of stuff on the web.
A clip :
Even-Order Harmonic Distortion
Tube amplifiers have much more distortion than solid-state amplifiers, but most of it is second-order, which is quite musical. That's why it's called "harmonic" distortion.
Second-harmonic distortion is exactly the same note, an octave above. Ditto for higher-order even harmonics; they are also the same note more octaves above.
Even-order harmonic distortion can be so pleasant that back in the 1970s the Aphex Aural Exciter was very popular in recording and broadcast specifically because it was designed to generate and add these harmonic distortions! You can still buy it today.
Why Tubes Sound Better
Don't forget also that amps with little feedback are a lot easier to design and build with crappy tagboard-style construction methods. More sophisticated amps built with cheap and nasty construction tend to oscillate.
That's the key reason that kitset amps tend towards modest or even mediocre. If you've got zero control over how the design is going to be built, then you've got to cater to the lowest common denominator.
Svitjod, if you read my letter, you'll know that I did my literature study in the 1990's, so already decades after 1966, and you'll know that I had an open mind about the issue and just wanted to know the truth.
Back then there were articles published in various Dutch electronics hobby magazines stating that you should not use too much overall feedback or no overall feedback at all because of TIM. When there were literature references, they always referred to articles by Otala's group, and when any arguments were given, they were always similar to those in the articles of Otala's group. The oldest articles of Otala's group referred to Daugherty and Greiner.
On the other hand there was the early 1980's PhD thesis of Ernst Nordholt, Design of high-performance negative-feedback amplifiers, which recommended using as much overall negative feedback as stability considerations would allow, which had a very short comment about TIM and which referred to the articles of Peter Garde.
Critically reading the articles of Daugherty and Greiner, Otala and Garde it became quite clear who was right: Peter Garde.
