In my opnion it is the 3. I have a little bit more air and better decay.
But it is a taste..
BR
Sonny
I tried, the most I like the filter 3 .
Thank you,Sonny.
BR
Hi Sonny,
Could you sell me four of those buttons? I need some for my front panel.
Do
Yes I can
Yes I can
Would they work with the preamplifier display? If yes, can you send me a PM with pricing for four?
Do
Hi, received the package. Xlr discrete output
I have problem turning it on
1. Voltage 5. 5v using salas reflector 600ma
2. 14.92v 1.5a a plus minus using just regulator
3. Display not installed.
4. Tried my handphone. Usb out, song still comming out of mobile phone speaker
5. Tried using dap with optical out nothing
What am I missing? Thanks
Test setup View attachment 644057
OK got it..
Sonny how much is the alps potentio? To work with this module?
OK got it..
Hi Anthony.
Got you the problem solved with SPDIF?
Hi Anthony.
Yes got it to work, thanks
Hi Sonny
I currently disable pin 3.
And that is the correct way AnthonyA to run in single ended. I have not made it active balanced, In active balanced you can short pin 3 or pin 2 to ground and get the double voltage swing on the opposite pin
BR
Sonny
BR
Sonny
Can you please make one post with all info about new DAC..
Anthony,
The only digital supply is 5,5V.
This is what you have to feed to the board, together with +/- 15V.
Or did you mean J11?
Pinocchio, do you mean the onboard balanced output connectors?
They are like this: (top view)
Se- | Se+
Gnd | Gnd
Se+ | Se-
The (+) amplifiers are summing the balanced dac outputs into Se + signal (upper row, below connectors)
The(-) amplifiers are inversely summing the balanced dac outputs into the Se - signal (bottom row)
(A very nice find from Sonny)
Se- | Se+
Gnd | Gnd
Se+ | Se-
Se- | Se+
Gnd | Gnd
Se+ | Se-
Yes, it was the onboard balanced output. Seems like they're exactly the same as the previous discrete output stage so I didn't have to change anything!
Listening starts tonight! Yessss!!
Ciao!
Do
- Vendor's Bazaar
- AK4490 USB Dac with dsd support.
