F6 Illustrated Build Guide
And/or chip quik. A little expensive but it works fantastic on hard to remove SMD components and I’ve used it for through hole stuff too. Check YouTube for ideas. EEV blog has some great videos.
YouTube
Alternatively, you can bridge all the pins together with a remaining resistor lead and heat all the pins at the same time in rapid fire mode while lifting the transformer.
Best,
Anand.
No idea. Possibly good. I think I might have some white berquist pads laying around maybe I'll get around to doing a comparison if I find them.
The thing is if you buy them and they are just ok later on you're probably going to want to buy the keratherm pads in which case you have wasted money like I did.
May as well get the best the first time around.
Has anyone tried Berquist Sil-Pads?
Are they comparable to keratherm?
To my non-engineer's eye, Keratherm appears much better on the datasheets. I have not used them, though. I am currently running Sil-pad 900S on one of my amps and can verify that I see case temperatures which are at least 30C hotter than the heatsink temperatures. This has me wary of pushing the dissipation higher, which was my original intent. There is, of course, a Sil-pad which offers better performance than the 900S I am using, but I've only found it available in large sheets, which are expensive and must be cut to size. Plus, the datasheet still suggests worse performance than Keratherm...
Like this. :wiz:
