Thanks Sonny, I'll wait for the parcel from you.
I have one more question
I accidentally deleted it from the USB stick received from you and from
computer this driver: Xmos-stereo-USB-Audio-Class2-driver-305C (v2.26.0)
I tried to get him out of here:
AK4490 USB Dac with dsd support – Discrete DIFF/SE shield, PCM Filter setting | Mirand Audio - Solidstate designs.
Can you please confirm that this driver on Mirand Audio - Solidstate designs is OK and has no problems?
JRiver runs Audio-Class2-driver-305C, but when I press the player, an error is always displayed.
I found that when I want to load in " xmosusbaudiost305C_dfuapp.exe " I always get a DLL error...
Thank you.
Best regards.
There is a new driver. I will find it and upload it.
I'm going to watch the site when it's loaded.
Can I hope that until Monday this will happen?
Thank you !
Windows driver.
Dropbox - XMOS-Stereo-USB-Audio-Class2-Driver-305C_v4.13.0.exe
Firmware upgrade guide:
Dropbox - Firmware upgrade guide.pdf
Firmware upgrade tool:
Dropbox - sam-ba_2.15.exe
Firmware for USB Audio DAC V1.2 with simple frontpanel:
Dropbox - SITO USB DAC V12 - Firmware - 20170921.bin
Firmware for USB Audio DAC V1.2 with OLED frontpanel:
Dropbox - Mirand Frontpanel - Firmware - 20170921.bin
https://www.dropbox.com/s/6nw39ktcfr8g1so/SITO USB DAC V12 - Firmware - 20170921.bin?dl=0
Windows driver.
sam-ba_2.15.exe
sam-ba_2.15.exe
Hi Sonny,
Now I understand, I need it to RS232 converter cable.
Can you tell me how do the wires (red-black-and-white) connect to the 3 connectors plastic socket?
When I want to upgrade to a simple front panel for the new DAC V1.1, where does the plug connect the USB to RS232 converter cable? (J12 or J13? )
Or are I wrong?
Please be to help me, I have tried in many ways and now I can not adjust the volume to the simple panel
Thank you.
Best regards.
Or are I wrong?
Thank you.
Best regards.
- Vendor's Bazaar
- AK4490 USB Dac with dsd support.
