There are very many parallels to the following:
My girlfriend (the best of all, of course) practices homoeopathy, TCM, acupuncture and some more stuff like these. Some time ago I accompanied her on a visit to a fair where esoteric health products were shown. All BS, btw.
There was a stand where the staff presented their so called Grander water. I went up to them and pretended some interested look at the device that processes normal water from the tap to give this Grander-ized water. The device had two identical fittings and no arrow to show the flow direction. This seemed somewhat strange to me, as processing water means adding somewhat to or removing somewhat from it, and therefore each processing device should have distinctive in- and outputs. I asked the stuff about the installation procedure and what would happen if I per chance would install it the false way. Would the water become worse than the raw tap water then? No comprehensible answer. Then I asked them to let me one device for testing. I insinuated they surely had some laboratory to analyze water. So, after the installation I'd send them ten samples in small vessels, five of them filled with just tap water and the other five ones with Grander water. I said if they were able to identify all samples by chemical or some other means without any doubt, I'd be very glad to keep the unit and pay for it. They disagreed. Of course.
Best regards!
Best regards!
I've seen a magnetically levitated speaker advertised, but don'tknow where I'd find one to listen to.
30 odd years ago, I lived about 500m from a railway bridge, which elevated for ship traffic, when needed for ships needing more than about 7m of clearance.
Sometimes deep sea vessel operators, or their pilots, would forget to switch to lower power transmissions, in these cases, I'd get to hear loud distorted 1/2 conversations blasing out of my system: Vancouver Traffic, Hecate Straits. Traffic, we are 10 minutes out, can you lift? Traffic, Hecate Straits, copy that. Will hold against tide for lift.
Copy 20 minutes. Advise when trains clear. Straits out.
I also lived 2 blocks from a stereo store, and the salesman was selling me power filters and shielded cables when his manager walked by, having overheard the situation. He advised me to go find ferrite clamps at a Radio Shack, or electronics store, and put those on all my cables, power and signal.
Only a few bucks back then, to do my receiver, turntable, and vcr, and lampvord speaker wire.
Never had the issue again.
Ferrite clamps are dirt cheap, still, and I still use them on my speaker wire, whether they block noise or not, I don't know.
Ferrite chokes are very useful in knocking down RF interference.
Also make sure your system is properly grounded.
Many RF Interference complaints can be traced back to the one who
is getting the interference not having their system properly grounded
and their connections not being securely tight.
Hey this stuff all started in Germany a LONG time ago Home | Schauberger
They were on it even back then...
Water prefers to flow as layers or strata rather than as streams, for only then can it perform its real role, that of absorbing energy from the quantum field.
What do you mean "properly grounded"?
In the case of using an external antenna for FM and fed by
coax make sure the outer jacket is tied to a proper ground
(usually through a ground block)
Use 3 prong power cords if the equipment calls for it
(dont' use an adapter to defeat this or cut off the ground prong)
Tie the equipment chassis to ground via the ground lug.
I thought you meant ground as in earth for safety, that's fine and good practice, it has little to do with suppression or screening of RFI however. A screen or faraday cage will work without being connected to earth
At a minimum it should be grounded for safety, many people don't even do that.
In severe cases (like people who live near broadcast stations) put chokes
on everything.
Back in the days of CB radio here in the States, I had a customer with a home organ that was picking up his obnoxious neighbor's illegal CB rig. Big linear amp, outdoor tower antenna, the whole deal. I was just a kid still learning, and tried everything I knew at the time, including installing ceramic capacitors across transistor junctions etc, but man, there were a lot of junctions in that little Wurlitzer Funmaker. I was able to reduce it but not get rid of it. Besides, there was so much RF in the air you could almost taste it - all the neighbors were complaining about various interference. Dude just didn't care. They even reported him to the FCC, but I imagine they were overwhelmed with this sort of thing at the time.
Anyway, the organ owner finally wound up sneaking over and sticking a straight pin through the guy's coax cable (and cutting it off flush!). Problem solved.
on everything.
Of course there are countless ferrite compositions, all which have different frequency bands. randomly glomming an unknown choke on is more desperation that engineering.
If I recall correctly Mix 31 for HF and Mix 43 for VHF
I have seen the same trick in a pub beer garden where the background music system was far too loud hindering conversation.........Anyway, the organ owner finally wound up sneaking over and sticking a straight pin through the guy's coax cable (and cutting it off flush!). Problem solved.
We asked management to turn it down to no avail.
A friend opened his wallet and removed a sewing needle and then inserted it into the speaker cable.
The level dropped markedly, then management turned it up, then silence.....problem solved.
Dan.
I've always wondered what the cosmic microwave background radiation levels do to the noise floor of an audio system.
I've also wondered what benefits there would be to heavily shielding any low level audio equipment such as opamps/dacs etc.
Obviously if 2% of the noise on a crt television set that is untuned is CMB then there would be some form of affect on the audio equipment, but it would be minimal.
But isn't there usually an AGC circuit on the RF side of most modern radio receivers?
On a TV screen for example, under no-signal conditions, we're looking at an "enhanced" noise floor caused by the wide-open AGC, right? If so, this would skew the comparison a bit, if we're trying to decide whether it's important that this particular noise is creeping into our (fixed-gain) audio circuits. It also raises the possibility that the video (and audio) noise on an untuned TV is coming predominantly from internal circuits upstream from the AGC, and not the cosmos.
I agree with your points, and yes the pseudo scientific stuff does degrade.Exactly.
If there were any physics to explain how Bybees work, they should publish it.
If, as has been said, it works and is unexplained as yet, they should say that, and provide the evidence that it does work.
Instead, they write a lot of pseudo scientific sounding guff, the only purpose of which can be to attempt to mislead the gullible.
If they are not honest, how can they expect to be taken seriously?
Further JB's unapproved usage of JC's good name and lack of financial reward does not go down well in my books, especially in the context that JB is well heeled indeed.
Pseudo scientific stuff aside, it is curious that BQP's do quieten and dampen audio systems, and proper physics explanations would stand the product in much better staid.
Dan.
...Pseudo scientific stuff aside, it is curious that BQP's do quieten and dampen audio systems...
Dan, you've just dismissed pseudo-science and real science in the same sentence. What's left?
Remember though that an untuned audio circuit is not a receiver and it has no AGC.
It doesn't even have the ability to discern or tune out interference and allow only one specific frequency through. It receives all frequencies equally at the same time.
But provided that sufficient shielding is in place only the signals which are present in the DAC/opamp circuits already should be there and no outside external influcence.
However, the outside shield of a coax poses an important problem, it is the final shielding in an important system which must be shielded from outside RF, currents passing along the outside of the shield can then pose a problem, which is where ferrite beads come in.
It makes me wonder though how much of the signal which is also passing along the shield/braid is being attenuated by the rf interference and we don't know about it.
And that is where dual conductor coax or twisted pair in a shield comes in, to mitigate against this. aka balanced line.
The thing is though, and this is where most people forget their basic physics, is that no matter what the frequency of an RF signal is at, it is still producing a magnetic field in the conductor, and a magnetic field being induced in a conductor doesn't matter what frequency its oscillating at, it will still affect all other frequencies which are being carried along that same wire.
And this is where audio signals being affected by RF comes into play. If you remove the offending signals at higher frequencies with a ferrite bead then they don't have the ability to produce the offending magnetic field in a conductor and so therefore the magnetic field cannot then attenuate the audio signals going along the same conductor.
That is why ferrite beads on an audio signal cable work at all.
Mind blown yet?
..say... what???field being induced in a conductor doesn't matter what frequency its oscillating at, it will still affect all other frequencies which are being carried along that same wire.
- Member Areas
- The Lounge
- Funniest snake oil theories
