SSLV1.1 builds & fairy tales
Joined 2009
Atlas needs a new battery or one of its clips cut out at cable's end because of use strain?
The device told me to change the battery, once changed display said:
"Self test failed: CODE: 6"
Contacted Atlas and answer was: "Code 6 indicates that one of the multiplexers has probably been damaged.
Your DCA55 will be the same circuit as the picture I sent you, so it is most likely that the analog switch U5 has failed.
You can either send the DCA55 to us to be repaired, which can be ordered in our Web shop, or you can try to repair it yourself by replacing U5, although I cannot guarantee that this will solve the problem.
If we repair it then you can be sure it is working, and the repair comes with a new 12 month warranty. "
Attached image IC to be changed.
I have a set of positive and negative power supply boards. I am shooting for a 9V output to 3 DACs. Positive supply would have a CCA of 750 mA. Negative would be 400mA. When picking out a transformer would a transformer with 15V secondaries work? The documentation said I needed to supply greater Vac than the Vdc I was looking to get.
For normal series regulators:
9Vac might do for a +-9Vdc regulator.
But this might reach drop out as the mains drops to lowest tolerance.
Play safe and go for a pair of 10Vac secondaries.
If you can't source 10Vac, then go up to 12Vac.
15Vac will make the regulators run too hot, since the input would be around 22Vdc
But shunt regulators need a higher volts drop across the current limiting section.
eg. the +-10Vdc from the shunt regulators of the DCB1 needed at least 13Vac secondaries, so we ended up using 15Vac.
