Hi. What is the value of resistor instead of NSL32? MJE340 / 350 is the need for a cooler?
NSL32 can be replaced with 47k resistor and LED for 'clip' indicate, if you don't want use limiter,
MJE340/MJE350 need some small heatsink.
Mr. Mile,
I'm planning to upgrade my B500 to TEF, is this correct?
I want to change predriver to mje15032/33 pair driver TTC5200/1943 pair and 5 pair mjl3281/1302 as outputs...can anyone tell me mje340/350 are equipment to mje15032/33 pair ? because I saw for tef version there all mje15032/33 instead of mje340/350.
https://m.youtube.com/watch?feature=share&v=myLK3RT_SL0
B500 with 2 pair output.
Hi Mr,can you give more details about smps?B500+SMPS
hi to all may i ask if i can use my 60-0-60AC trafo for B500 orig design 8 outputs using 1943/5200 or shall i use MJL/MJW for this voltage?
thanks
regards...
Use MJL, or NJW 21193/94
Sajti
Sajti
...or MJL/MJW/NJW 21195/96, which show about the same specs, but are (why?) somewhat cheaper than their 93/94 counterparts.
Btw, any objections against faster devices here, such as MJL4281A/4302A?
Best regards!
thank you so much for the reply...
especially to Mr. Mile...
i am sorry for asking too much, it is my avidity to these things constraining me to solicit advice, learning electronics through ethernet is difficult but because of the support of this forum all my apex designs are working great compared to available hi fi or mid PA in the area. (b500, sr200, ax14, ax20) next in mind is the Hclass, but i have to go to school for now soon i'll do it after parts are complete.
best regards...
sam
best regards...
sam
- 500W PA amplifier with Limiter
