Simplistic MosFET HV Shunt Regs
Joined 2009
It seems CCS works well with LV, attached pics, dummy load 220R.
Slave Regulator vs SSHV2
Dear Salas,
Assume the master regulator retain in the power supply, what would happen if replacing the slave regulator (the one close to signal path) with your SSHV2?
What the differences between slave regulator and your SSHV2 for this application?
Thanks!
diyAudio Chief Moderator
Joined 2002
Its little CCS range for Q1 & Q2 nonetheless. They usually go up to about 100mA in this arrangement. Measure R5. Is it 10R indeed? If no and its higher by mistake restore to 10R. If yes its 10R, weird CCS result if so, try 1R (1mV=1mA TP). Also check if R4 trimmer & R3 resistor are good.
