Valve Itch phono
Joined 2009
diyAudio Chief Moderator
Joined 2002
That's a build level thing, you can only find, but check if the infrared is broken or a resistor, whatever is in that same "tree". You should see voltage drop across the series resistors when the respective tube section is conducting. Then translate to mA from Ohm's law regarding their values.
