The load needs 20mA, 10mA for each triode.
10+10=20mA. +20mA we usually recommend for SSHVs own=40 mA CCS is better. + more mA if the triodes will swing high.
Attached schematic used.
See that the anode transformer's shell is also grounded not to pick interference.
Attached transformer pic, do you want that I connect the transformer to signal ground?
If the chassis is already referenced to signal ground, no, if not, yes.
The B+ voltage is set with the -3.3V grid bias?
- Power Supplies
- Simplistic MosFET HV Shunt Regs
