Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
Hi, Dimdim,
Could you elaborate a bit about why a filter with 3db headroom is more desirable? Also what filter would you recommend for Soekris? Thanks.
WYAN
RAW SE is 1.4VRMS = ~4Vp-p
Regarding the "normal reference levels", there really isn't a standard per se.
Most DACs and CD players output 2VRMS..
Btw, the DAM's SE output of 1.4VRMS goes to ~1VRMS once we load a filter that has 3dbs of headroom (we should be using such filters IMHO..).
So far I've been using a transformer with dual 15V 1A secondaries. Plenty of power.
Now I'd like to switch to a transformer with dual 15V 0.5A amp secondaries.
Thanks!
That was my first setup, 2x15V 1A and the LT3042 from DIYINHK on 12V.
Lots of heat on the LT3042 and also on the dac.
Now i use 2x9V and LT3042 on 9V, no more heat. Sounds even better (less stress).
Nice to hear Soren confirm that 9V is enough.
One more question regarding the output. :)
We have the choice of the RAW SE output or a balanced one. Is there anything to gain by adding a buffer/output stage to the single ended out? Building the buffer (phase splitter?) could be fun but if it's just unnecessary or even likely to degrade the sound, then it would be a little like shooting yourself in the foot and paying for the privilege to do it.
I've been wanting to play around with tubes but I don't want to be stupid, lol. My amps have a fully differential input.
Sounds like your setup is a good candidate for dual-mono. I run raw outputs straight to headphone buffer and amplifier, no longer using the onboard buffers.
Another view - I only use the RAW output. It drives a Slagle autoformer attenuator which then drives two stereo amplifiers and an electronic crossover. It seems to drive this with ease. My speakers are very high efficiency which might make a difference.
I tried using the same buffer circuit Pass uses in the FIRST WATT buffer (with a much better power supply) and found it sounded better without the buffer in the top half of the spectrum. Conversely, it had much better defined bass.
I then moved the buffer after the attenuator into the lead that goes to the amplifier and crossover that handles 500 hz down and I am getting the good that heard from a buffer right after the DAC without harming the upper frequencies.
The raw output is robust. I think you will need to try in your system to find out what works best.
Another view - I only use the RAW output. It drives a Slagle autoformer attenuator which then drives two stereo amplifiers and an electronic crossover. It seems to drive this with ease. My speakers are very high efficiency which might make a difference...
Rick, I'm curious, did you try using the built-in digital volume straight to the amps? How did it compare to the Slagleformers?
I am a fan of TVC/AVC attenuation but have been living happily with the digital volume control. A friend for whom I put together a 1021 is a tube adherent but ended up putting his tube preamp in storage after hearing the 1021 straight into his power amps.
It's just a quirk of mine, I like challenging modern problems with stone age tech. Tubes done well can go toe to toe with transistors but forget about the tube part for now.
Is it worthwhile designing a buffer stage for the output or is it better to just stick with the RAW output as it is?
IMHO if the DAM's 1V RMS output is enough for your preamp or amp, and if your preamp or amp is a relatively easy load, it's best to avoid adding a buffer (or preamp) stage.
Adding a buffer stage will give you (for the most part) immunity from cable & load characteristics but if not done extremely well it will degrade the sound.
Using raw outputs directly into a class a poweramp. Digital volume control. Never looked back. My tube gear rests in the closet
This, have been running straight to the amps since my initial setup. The digital volume attenuation doesn't cost anything and the less stuff in the audio chain the better IMO.
All of my tube gear was single ended thus went away when I went balanced end to end, that and having to pay an electric bill since moving was the final nail in the coffin.
IMHO I find it hard to believe that anything tube-related will actually improve the DAM's sound..
This depends what you are feeding with it. The unbuffered output is too weak to drive 10k input of my Genelecs convincingly. I have a very nice 2A3 tube amp as pre, and it's different story. Soundstage gets 50% bigger and dynamics are noticeably better/explosive. Only tiny downside/or coloration is the slight wetness to it. And in my experience no solid state competes as buffer or preamp with tubes. Solid state ultimately is veiled or dull in comparison to best tube amps.
