CSR8645 Bluetooth 4.0 AAC APT-X Module / Baseboard
yes, I have also spent weeks trying to get the pcm interface working. After having read all possible documents mainly from chinese sites, and tried many configurations, I am also stuck.
I hope that one day someone comes with some functional pskeys for the digital audio IF of the csr8645 module.
I have bad news.
I had dump for this, but it was done time ego, so tomorrow i will try find this dump on work pc.. I spend some time to find this and try to configure for spdif, but i do not remember how to do this;)
But nothing lose, i find this dump.
This chip was pure (no configure) so i put this to box and do not use anymore;)
Offcorse i tryed setup i2s, so no possible now to recover dump from chip.
Please, forgive me, i promise to find this;)
Ok, so
Dump is here:
https://drive.google.com/folderview?id=0B6L6UWHrZEEKRjlYS0lseEhLazg&usp=sharing
SCR8670, You can setup csr8645 the same, I have to check it.
Connection:
Mobilephone=>bluethooth=>csr8670=>spdif=>74HC157=>AK4113=>is2(master, left jus.)=>PCM5102A=>analog.
Sampling spdif 48KHz.
Thanks mate, but this is still a 8670. :D
The dump is from your 8645 module?
On the 8670, I2S is working as well.
Edit:
So maybe this is the magic:
Code:
// PSKEY_PCM_CONFIG32
&01b3 = 0080 0900
// PSKEY_USE_OLD_BCSP_LE
&01b4 = 0000
// PSKEY_PCM_FORMAT
&01b6 = 006c
// PSKEY_CODEC_OUT_GAIN
&01b7 = 0007
// PSKEY_CODEC_IN_GAIN
&01b8 = 0108
Ok, so my opinion:
// PSKEY_HOSTIO_MAP_SCO_PCM
&01ab = 0001// True
// PSKEY_HOSTIO_MAP_SCO_CODEC
&01b0 = 0000// False
// PSKEY_HOSTIO_MAP_SCO_PCM_SLOT
&01bd = 0000
&01bd = 0000
// PSKEY_PCM_FORMAT
&01b6 = 006c
&01b3 = 0080 0900
// PSKEY_HOSTIO_MAP_SCO_PCM &01ab = 0001// True -enable stream to pcm
// PSKEY_HOSTIO_MAP_SCO_CODEC &01b0 = 0000// False - disable use codek
// PSKEY_HOSTIO_MAP_SCO_PCM_SLOT &01bd = 0000 - route to pcm0
// PSKEY_PCM_FORMAT &01b6 = 006c - format pcm (bitrate)
// PSKEY_PCM_CONFIG32 &01b3 = 0080 0900 - master,slave,left,rigth justified
But 8670 still stream to spdif:)
Now i try setup this to 8645
About pskey 35 and 36
This is keys to setup pcm also, but in datasheet are 11 words, in 8646 only 10.
This was divide ( first are in 35, second in 36).
You can there also setup i2s, but documents are not corresponding to 8645 keys...
I changed there also something, but no have note what.
from my trials, the 3rd word of pskey 35 seems to be related to volume attenuation.
I thought I might purchase a cs8645 bases bluetooth - spdif bridge device to read its pskeys ( see this blog for device insight Aptx Bluetooth 4.0 music receiver )
I wonder what role does the 128kbits flash device play in my module or the one (which might even be bigger) on the above link.
