Input resistance is very high but differs in CM and DM and depends on frequency, so what value do you want.
I' puzzled why you need a trafo, is there some large chassis voltage to bridge?
When that is the case and you definitely need a trafo, you better place a fixed resistor on the secondary side between 10k and 100k.
Hans
Hans
Does any have handy the input impedance for this preamp?
I need to connect an input trafo which will require a resistor on the secondaries based on the input impedance. Thanks
My guess is that you want to use this preamp as a kind of a volume controlled output stage for a Dac which uses a transformer as I/V .
Is that correct?
One more time. Does any have handy the input impedance for this preamp?
One more time (to save Hans from repeating himself):
Hans
If you answer Hans' response, I'm sure he will give you an answer... got to put in the effort.
Anyone have a dxf or something for the preamp for a back panel? Since the pcb has no fastening holes.
Bas I have a front panel express format panel drawing. Does that work for you?
Jan
Is that correct?
For clarity, I need the value on the input impedance of the preamp because this will determine what resistor value I place across the secondaries on an input trafo.
Still no sign of my board which arrived in Canada less than 24 hours after posting in the UK.
After countless hours on the phone to both Canada Post and Canada Customs, navigating menus that are designed to make it almost impossible to speak with a real live person, I managed to confirm that my board is 'probably' at the Vancouver Customs Clearance facility and that they are currently experiencing a turn around time of up to 46 days!
It seems a shame that for all the effort that Xavier went to, to be undermined by Canada Post and/or Canada Customs - one has to love the unions!
Clive
Thanks to Canada Post having taken well over two months to deliver my board, and despairing that I ever would receive it, I started constructing a different preamp instead.
Which means, that the assembled group buy board I now have in my hands is surplus to my requirements.
I am willing to let it go for exactly what it cost me $61.50 USD plus postage (which I can quote on when I know the intended destination) to the first person to respond. Payment via PayPal only.
Thanks,
Clive
Hi Clive,
I am interested to your spare.
Please send me your paypal account.
Shipping to Korea.
Thanks and Regards,
Enrico
Hi Enrico,
You are the first. I will confirm the shipping price at the post office tomorrow. I will let you know via a private message.
Everyone else, please consider it sold.
Clive
Hi Enrico,
Clive
Thanks Clive.
Best Regards,
Enrico
Yes please!Bas I have a front panel express format panel drawing. Does that work for you?
Hi tfboy,
If you end up with some leftover PCB's - then I would like to buy one.
Preferably a BPPBP SMD assembled PCB + a pair of Hypex regs.
Kind regards,
Michael
Please overlook this post. I have already ordered some PCB myself.
- Group Buys
- Bruno Putzeys Balanced Preamp - Group Buy Part 2
