And...I'm seeing 7mV and 4mV DC offset at speakers where I was seeing over 100mV on the right channel after it went out. Hooked up speakers and its singing again on both channels. Turned it off after 10 seconds. I may still have an over heating issue somewhere. I suppose the good news is no components have completely failed.
Not seeing any smoke if that's what you mean. I didn't leave it on long enough to check any other voltages. When right channel went out followed by left 10 seconds later, I had played Aux for about 5 minutes and just switched to Phono to test it. Music cutout after about 2 minutes.
My new DMM has Capacitor tester. Should I pull and test some of the original electrolytic caps on the Voltage Amp Assy? Or would an overheating issue likely be one of the transistors on that board?
No. Ignore the caps, don't remove anything. You don't want to introduce new problems.
Measure idling current. Put meter on an emitter resistor and tell us the value (in mV). Do this for both channels.
- Pioneer A88-x with Bad Channel
