"Reference" TDA1541A DAC with I2S-BUS architecture
Surface Finish for future PCB´s
  • ENIG - Electroless Nickle/Immersion Gold
    Votes: 93 48.7%
  • Immersion Silver
    Votes: 54 28.3%
  • Immersion Tin
    Votes: 24 12.6%
  • OSP - Organic Solderability Preservatives
    Votes: 20 10.5%
  • Total voters
    191
Hi Ton,
if you want to use two Red Baron DAC´s parallel with the onboard I/V stage, you must connect it like this:
1st - Every DAC module needs all parts of the I/V stage, expect the I/V resistors. Adjust the DAC output to 0V (DC-offset of the TDA1541A).
Don´t forget to make the small modification and switch the source and drain of the MOSFET like in this picture !!!
2nd - The output of the current buffers on each DAC module (inner four-sided point of the I/V resistor) must be connected together (parallel).
3rd - You need only one pair of I/V resistors with 250R value on one DAC module (four-sided / round point).
4th - You connect the DC-Reference Module as followed:
From DAC module
Ref. (Audio out) --> Ref. +5V
GND (DC Digital) --> GND
From DC Ref. Module
GND Ref. Left --> GND RCA Left
GND Ref. Right --> GND RAC Right
You could see it on this photo
5th - Trimm the RCA GND to 0V
That´s it. ;)
Cheers
I am just about ready to build a Red Baron Dac, using two Red Baron v5.0 DAC´s in parallel with the onboard I/V stage. Please let me know if there are any major changes to how it is done from the quite ancient post featuring the v3.0 boards above?
Thanks in advance!:)
Got these at the post office today, thank you very much Oliver :)
Joined 2009
Hello, friends of the 1541a.
Has anybody tried using Beaglebone Black or Odroid C1+ with direct i2s output with the Red Baron? This USB to i2s thing is becoming a bit to complex for my liking with elaborate computers, USB-isolators, regenerators and whats not. And with some reviewers reporting that the plain old Spdif sounds more musical and dynamic than USB I'm starting to think that simpler may be better. Any views and/or experiences?
