Dual Mono DAC AK4490/AK4497
An other base to mod with ? AK4490 - I2S over USB Audio
Nice board, but this doesn't have implemented like i see on the board the large value capacitor between VREFH-L/R to improve THD performance, refer to the eval board manual.
Anyway now with some input direction from some post there, i will sugest to go with following line:
  1. 4 Layer board (minimum)
  2. Implement a Large Capacitor on VREFH-L/R to improve THD on audio bandwidth... >=2200uF (see attached graph)
  3. Balanced / unbalanced output (mean 2 LPF/mono DAC)
  4. LDO - LT3042 on board for providing the 2 * 3.3V with Ultra low noise and Ultra high PSRR on Digital side. (perfect will be 4 LDO/Line for getting 0.4uVrms noise for up to 800mA max. this should be optimum for the DAC(>=150mA) and/or the XMOS board (>=400mA)
  • Should we made the same integration on board for the 5V/7V Analog part with only 1 LDO/Line (0.8uVrms, 200mA) this as sense but we could over dimension this with 4 LDO/line to stay on the Ultralow noise of 0.4uVrms ???????
  • Then also for the dual LPF for each mono AK449X to get the Balanced output line with +-(12 or 15V) ->this should be able to be switched on board easily depending on Opamp choice, should we there also go on the same idea to provide the ultralow noise UltraHigh PSRR -> this has logical improvement for me.
  • The three before proposition will say we should provide 5 isolated power 2*5V DC for the 3.3V(digital), 2*9V DC for the 5V/7V (selection on board) analog and 2*18V DC for the LPF with +-(12 to 15V) -> Some input of the 7V setting on Analog improve the THD+N but this should be checked before doing it selectable.
  • But i should not forget that the AK4497 need a clean 1.8V , clear this provide one in chip LDO for, but is this better than the LT3042, really not sure so there i will go to provide on same way the 1.8V form the LT3042 and switch off the internal LDO.
Any comment will be great on this direction ?
Agree with everything, but you don't plan to put a Xmos on each board ?
Selectable just with a jumper could be great.
Yes I know that, search for a hifiduino link... I didn't remember the DIYinhk had this "tweak" on-board, far away from the DAC but implemented yes...
Ok, I'm waiting for updates now :D
If the aim is ultra-low PSU noise, then variations in load current absolutely have to be minimized or the regulator's own noise will be swamped by load-current induced noise. Getting the load current variations down is rather tricky when opamps are in play (the SCFs at the output of the chip are generally CMOS opamp based) because opamp output stages don't operate in classA.
Let begin to build the board XMOS isolated (or not isolated) with AK4490 firmware and AK4490 board from DIYINHK.
BOM:
1 - Transformer R-core 2*9V, 2*15V or Toroidale 2*9v 2*15V (2*18V) (>=30VA)
2 - Regulator board 2*3.3V, 2*5V (5 to 7V max), +-12V (+-10V to +-15V Opamp need)
3 - XMOS isolated (or not) with AK4490 firmware
4 - 100uF electrolytic (>=10V) from Panasonic or better is to filter the optional Analog 5V supply.
5 - AK4490 DAC board
Customize the AK4490 board to provide 2*3.3v , 2*5V to split both digital/analog Ops.
Refer to attached screenshot (1) remove the FB1 to split the 3.3V provided , by adding up to the FB1 3.3V power.
Cut the trace (2) to split the 5V provided on board by two separated 5V, new 5V supply provided under the point (3) .
On (3) solder the 100uF capacitor.
The board now should be cleanly powered (with more direct power line than before ;)
Enjoy your DAC and connect everything by controling any pin to match also don't forget the PSN jumper to set the software mode (for operating trough the XMOS board)
Next we will create a new AK4490 board (base for the AK4497 when sample requested by AKM is delivered)
Board D1
- Dual AK4490 on board
- Balanced/Unbalanced analog output
- Ultra Low noise with High PSRR LDO on board (LT3042)
Board X1
- Usb XMOS board (with firmware supporting native DSD 256 and if possible PCM 768khz/DSD256 -> currently i working on)
Board S1
- AK4118 board for Optical, coax .. input selection
As you plan to use onboard LDO, do you think it'll be possible to use big external PSU in order to power 3 boards together ? One 5V/7V and one +-15V ?
That project seems nice :)
For sure you could for your 6 channels system the VA should just be right dimensioned on your transformer.
I like to provide one litle transformer by channel for your need one personalized toroide with 6*9V + 6*15V at >=90VA (120VA) then 12 graetz bridges and 12*5600uF all take place but will provide optimum power supply on my point of view , is just my point of view ;)
Back from vacation, I am working now to program the XMOS XUF216-512-TQ128-C20 , already integrated the Vumeter over GPIO as I2S interface, I am just now trying to find out the device address for the AK4490 (diyinhk) to configure the DAC on data type coming from the USB interface to have output depending on sound source.
I got already the vumeter runing (move right by sound input) and could now put on the Oled some information dynamicaly, i will today test and integrate the specific AK4490 configuration to configure on need the DAC register. I hope to have the basic firmware ready til end this week (with volume up/down and filter selection)
After i will optimize everything for performance to be able to reach the max power this DAC is able to deliver -> to be ready for the AK4497 when AKM deliver me the sample.
Hi Manudrz,
This is my first DAC project, i design before a nice powerfull MOSFET (IRF) power amplifier with a passive preamp.
Yes i do everything "modulable" is i think the way for us to have any time the possibility to upgrade, control every part and build a stereo , 2.1, 5.1, 7.1 or more depending on need (i will go surely finaly for a stereo and 7.1 version).
The Xmos board (usb, S/pdif, coax) board is able to deliver 6 channels at 384khz, 8 channels at 192khz and up to 32 channels at 48khz, so to answer on your need only for the DAC boards this is able to deliver the 24bits 96khz you want to deliver over your DSPiy... (The DAC could 16,24,32 bits at up to 768khz) with I2S and I2C interface to have full control + H/W interface.
Very Nice.
However how you control two 4490 in one I2C channel? since the DAC got some ID
Maybe need to use 2 MCU to control 2 DAC
Very Nice.
The AK4490 as a 2 pin CAD0 and CAD1 as sub adress so you could build a 4 DAC board controled only with one MCU, I was also thinking about for a balanced version with this config because the DAC as also an inverting function in configuration register
Not many people building this DAC so I thought I would share my experience. I have separate super regulated power supplies for the Analogue 5V and the analogue 3.3V. Separating out the Digital 3.3V was not a huge subjective difference in SQ. However running the Analogue voltage at 6.8V was miles better. More clarity and density to the sound.
I am currently using the same filter/ buffer circuit as the evaluation board with different resistor and capacitor values. In terms of op amps I have tried various including LM49990, LM47910, AD4489 etc The cleanest sounding is LM4990. However the one that I am using is a current feedback Plano - LM49713. The high output current and slew rate makes a big difference. Best clarity and bass response too! I would say that this chip is equal to or better than the Sabre ES9018[emoji846]
Sent from my iPhone using Tapatalk
Forgot to mention that I am running balanced out and the next step is dual mono if I can get some code sorted.
The only issue I have is extremely loud clicks at the start of music and whilst navigating apps on my Nvidia Shield TV. I think it might be something to do with the USB initialising. Anybody know whether these can be soft muted in serial control automatically?
Do you use akm4490 in software mode or hardware mode ?
I have separate super regulated power supplies for the Analogue 5V and the analogue 3.3V. Separating out the Digital 3.3V was not a huge subjective difference in SQ. However running the Analogue voltage at 6.8V was miles better. More clarity and density to the sound.[emoji846]
Hi, was this increase from 5V to 6.8V with the same regulator? I'm currently running my AK4495 with a 5V PH shunt reg, and contemplating giving it another couple of volts. Ta.
Yes I am using the same regulator. The absolute maximum rating is 7.5V which must not be exceeded even under transient conditions otherwise you risk killing the DAC. AKM do not recommend running it higher than 7.2V
