D'uh. Forgot the original source. Will go sit in the corner with the cone of shame.
Please continue........I was going to go on about power supplies.
Dan.
So just what might be/are the root causes of distortions attributed to capacitors, if DA is not the prime culprit ?.
That might depend on the capacitor. I suspect there's more than one "root cause."
So, please discuss.That might depend on the capacitor. I suspect there's more than one "root cause."
Not far back IIRC you mentioned your professional knowledge of dielectric materials.
What are the suspicions that you have.......enquiring minds are interested.
Dan.
So, please discuss.
There are known non-linearities of dielectrics:
dC/dT (temperature)
dC/dV (voltage)
dC/df (frequency)
dC/humidity
DA does not seem to be the cause of any above.
But I assume you are just trying to poke a bit of fun at this current puddle of poo.
Yes, I am quite unhappy with the present wave of insults.
That's why I said 'postulated'.Really? I have not seen any proof that DA is the distortion mechanism.
AFAIK aso there are no formal 'proofs' of DA causing throughput distortion.
After digesting your measurements over I expect a wide range of capacitor types, do you have reasons for capacitor throughout distortion ?.I have also made a lot of capacitor measurements, but would not say distortion was a result of DA.
That's why i mentioned level/operating point shifting...this can cause dynamic long period distortion spectrum changes.DA makes longterm time domain errors, in frequency domain errors at very low frequencies, most probably linear errors rather than non-linear distortion.
Dan.
Dick Marsh claims that he does, but he forgot what they were. So see if you can jog his memory.
dC/dT (temperature)
dC/dV (voltage)
dC/df (frequency)
dC/humidity
What is meant by dC/df (frequency) non-linearity ?.
Is DA not a VLF non-linearity ?.
Dan.
dC/dT (temperature)
dC/dV (voltage)
dC/df (frequency)
dC/humidity
Dan.
So what really is DA ?.
A cap can be shorted for a relatively long period and then return a voltage ramp.
Why ?.
Dan.
DA in those C elcaps?
Would not you rather take care about diode switching transients?
You raise a good issue. Standard practice is to put capacitors across each diode. I have seen 10 nF suggested as the value.
JC of course uses a diode that has low switching noise.
I forgot to make one thing clear, this discussion is about low power supplies as would be used in preamps!
There are so many places to start the discussion.
AC mains noise?
Avoiding unbalancing the transformer?
Diode noise?
Transformer noise?
Surge currents?
Ripple?
Filtering vs frequency?
Circuit theory components not shown in the schematic?
ES
Why ?.
Ok, simple description.
A capacitor is essentially two conductive plates separated by an insulator (dielectric). When you charge a capacitor by putting a voltage across it, you're basically sucking electrons off one of the plates and shoving them onto the other plate. So now one plate has a net positive charge from removing some of its electrons, and the other plate has a net negative charge from putting an excess of electrons on it.
So now you have a force between the plates as the positive plate is pulling at all those electrons on the negative plate to try and equalize the charge.
Dielectrics are insulators, but they're not perfect insulators. And some of those electrons on the negative plate will slowly move into the dielectric. Sort of like a sponge, which is why DA is also referred to as "soakage."
However the movement of electrons into the dielectric is very slow. So if you short the capacitor and discharge it for a shorter period of time than you charged it, not all of those electrons in the dielectric will have had a chance to make it back to the conductive plate.
This gradually happens once you open the circuit again, and now the negative plate, which had equalized its charge with the positive plate during the short, begins to become more negative again as the electrons that were absorbed into the dielectric previously return to the plate, and so you begin to see a rising voltage across the cap.
I'm pretty sure this is a pretty accurate description of the phenomenon. I'm sure SY will correct me if it's not.
se
Did someone measured the energy ? The one restored during the first short circuit, the second one after the cap recharge itself etc. ?So what really is DA ?.
Why ?.
Can we model a high DA cap by a normal one paralleled with an other one of high value and high ESR ?
So how does DA cause distortion, if indeed it is a cause.
Mr RNMarsh (also JC,SW, Bateman and others) has done measurements and come up with the postulation that DA is one cause of throughput distortion in capacitors of various dielectrics.
The notion that a capacitor can be briefly dead shorted, and then delayed wrt the initial short circuit event return a positive, albeit high impedance voltage/energy output implies some kind of return energy slew rate function/limitation.
This effectively very slow slew rate function could cause subtle level shifting of DC operating points in the presence of asymmetric signals....IOW audio signal and not sine test tone signals.
Dan.
Ahhh. A couple thinkers in the crowd..... First off, you have to realize that energy stored in the Cda portion(s) is not readily available and is subtracted, if you will, from the total energy applied. Can the output then be exactly the same as the input in real time?
Later, the soaked-up energy is released into the external circuit at the Time Constant of the RC rep DA and the external Z.
For the thinkers.... how much later? Suppose a uni-polar impulse waveform with a period within the audio range. Will the DA/TC release modify the original waveform? How so? This one form of distortion.
The primary comparison was bipolar vs film..... that was the issue of the day. So, in your model, use a bipolar cap.
THx-RNMarsh
This makes no difference to the linear or non-linear nature of the distortion.
Ahhh. A thinker in the crowd..... First off, you have to realize that energy stored in the Cda portion is not readily available and is subtracted, if you will, from the total energy applied. Can the output then be exactly the same as the input in real time?
For the thinkers.... how much later? Suppose a uni-polar impulse waveform with a period within the audio range. Will the TC release modify the original waveform? How so?
So where's the non-linearity?
se
- Member Areas
- The Lounge
