I measured many hundreds of lsk170....................Looking for Matched quads of 2SK170-BL.
How many pieces would I need to buy, to come up with 2 matched quads?
I see 50 Pieces for $33 and 20 for $13, on ebay..
I found lots of matched pairs which I sold on at low cost. All the b grade are sold. I still have a grade and c grade in swap meet.
But I did not find any matched quads.
Matching requires both Id and transconductance to be equal.
This is a very sensitive measurement and the chances of getting a quad set seem by my experience to be very low (zero quads from 300pairs)
However,
if you are ONLY selecting by Idss and completely ignoring gm, then it is very easy to select by Idss, so easy it is recommended regularly and by many to DIY.
You don't need to pay the exorbitant prices I see being asked for selected Idss pairs.
Out of a batch of 100 devices you will get at least 40pairs to better than 1% of Idss. The remaining pairs are likely to be better than 5%
= virtually no wastage.
Lower THD due to higher Yfs and narrower bandwidth due to higher Ciss. About DC offset, matched Idss criterion stands the same although such high Yfs JFETs tend to be even more temperature susceptible than K170.
Thanks for the info Salas! I'll stick with 2sk170.
Dennis
New owner here. Which resaistors exactly got most influence in sound? how many of them are most important?
I found 4 at output but see 8 of them
http://www.audiocircle.com/index.php?topic=85001.0
The front row pairs near the PCB's edge flanking the signal output connector have two 220K and two 1Meg ones. Those are in parallel to the signal and less important. The 220R (Ohm) ones are in series to the signal, hence more important. All in all those eight are the only ones related to the L & R signal paths. You can use 200R instead of 220R.
Saw such posts before - I need to change some resistor right? I dont want to use monstrual heatsinks. Some small ones are preferred or maybe Id use bottom of case after putting DCB1 inside.
Thats hot rodded version right? Better sound overall? Better conditions for elements? Curious.
Those two pairs of resistors flanking the big electrolytic capacitors set the current flow in the MOSFETS. You can almost reach 200mA with 20R 2W replacing each of those resistors. No need for really hefty sinks, 200mA is just moderate hot-rod. The big semis run better with more current. You will need insulation pads though for common metal sinking between those MOSFETS. TO-247 sized Sil-Pads .
Trying to learn. So one 20R 2W resistor in place of 2 parallel ones right?
I found guideline for next step - 600mA. Smalll heatsinks (or moderate) would be still enough or Id kill Mosfets? Also is there need of changing MUR diodes for 820? I also noticed I got quite big transformer so it should be ok.
2A hot rod is beyond my imagination
Thank you Salas - I will make small steps comparision. Maybe even increasing current to 200mA first
One 20R 2W in place of each now resistor in a pair, four in total, making 10R per side since in parallel. 600mA starts asking biggish ones and its suitable for DCB1 Hypnotize which has heftier bridge diodes and more PSU caps. You stop at 200mA. Which is the most popular step by the way.
Technical question. I dont want to desolder MOSFETS.
1. Is there a problem if heatsink touches 20R resistor leg? If YES...
2. Would it be ok to mount heatsink upside down and get worse cooling for MOSFET?
If both cases are wrong ten maybe Id try to solder resistors at the bottom of PCB.
Solder 20R resistor on top of the other parallel 20R next to it which is further from the sink. Let an air gap between them. Or insulate the touching spot as Andrew said.
Don't mount those sinks upside down. Not enough MOSFET back contact. By the way the sinks are small, get bigger if you will have more than 70C on them.
I mounted resistor under PCB - maybe its even better for "cooling"?
Ummm I cant check temperature and I suppose organoleptic checking wouldnt be enough as 40- 50C could be hot for finger
Both pair of MOSFETS get hot equally or I could get bigger heatsink for some pair? Im asking because I got bigger heatsinks but only 2 pcs
if use the sink like that ..why you use High power mosfet ,...just use small type 1-2 Amp
- Mezmerize DCB1 Building Thread
