Graham Holliman Velocity Coupled Infra Bass Speaker?
synergy said:
it does exist, the patent's here
i'm interested in this
why is it so room fussy tho? is it simply because of having to presurise the space enough to produce these frequencies?
why do you say that if you turn it up the worse it sounds?
any ideas on how to work out the required chamber volume and port sizes for any given driver?
MAYBE
start with what you know. its a 'tline' with sealed chamber on the end. Perhaps start with the sealed chamber resonating at say,50hz with the driver on it,as per normal. Then work out the port for the same sized box,tuned low,then see if it works :p
Perhaps only low excursion woofers were available or,
loading is not sufficient to provide decent spl with low cone movement
(makes me think it is being used where it shouldnt be)
Finished typing out plans
Hi all you bass (infra) fanatics.
I have finished typing out all the plans...under huge pressure from you bunch!!
Anyway, Ill post the plans, all typed out by me ;o) as well as all the diagrams, as well as my personal experiences and tips i can help you with that i had to figure out on my own, as well as include all the tips i wrote in here. I see so many people have downloaded the plans up to where i typed, so ill rather fishish it and post it in a day or two once and for all, then I just hope you all build and tell me your results and hints you come up with.
Ill post on the 16 June latest. Its a public holiday here in South Africa, so ill complete it then. (Yes its winter here, and we sitting in 3 degrees centigrade morning temperatures. We not used that cold here.
NOTE : Also as paradise-ice explains, infra bass can be dangerous to health and property. In fact listening to the same low bass piece for two hours for testing and positioning of my new box, i ended up with neck-ache, dizziness, nausia, and had to have a break for 3 days before i could listen again....all that on a tiny system....be careful!
Answers to some Q's
Some questions
Q. why is it so room fussy tho? is it simply because of having to presurise the space enough to produce these frequencies?
A: You will see in the plans why you need a SUITABLE listening environment. He explains, but not explicitly says that the box raises and lowers the overall pressure of the listening environment. It stands to reason then that if you leave the door open, how do you pressurise the room. If you have a hole in your car tyre, how will you pump the wheel up to its correct pressure?
Q:why do you say that if you turn it up the worse it sounds?
A: Good question. Remember i was on a tight students budget. I only had an 80W rms 10" speaker, and a 30Watt rms NAD amp.
Of course if you turn it up too much, massive distortion is going to take place. I dont have a huge amp, and powerful speaker to test it to the limit. Besides i didnt want to kill thy neihbour. I would love someone to try this box with the more powerful equipment. Remember the distortion is also less the softer you play the speaker (within reason) and i found that the less the cone moved, the deeper, and purer the sound was. I dont believe my amp could drive it.
Q: any ideas on how to work out the required chamber volume and port sizes for any given driver?
A: Dont worry about that. The plans ill post on 16th june include 3 designs. All dimensions included to build a 10", 12", and 15" design. My 10" blew me away. 15" i think would stop your heart.
When youve heard bass down to about 10Hz or so...its indescribable, and youll understand what i mean then.
ryan
Whilst the principle might be capable of producing very low
frequency bass I'd suggest the caveat is that this is not
accurate low frequency bass, transient response is poor.
I think this can be observed by simple inspection, just consider
trying to use the principle for say bass in the 30Hz to 50Hz region.
I remember the whole debate about the principle well, and I
was basically in the sensible camp, saying that considering
the principles of vinyl reproduction the idea is at best a novelty,
getting down to 20Hz with good quality is far more important.
GH's suggested mods for tonearms were / are a non-starter.
With digital its very different if your subsonically inclined, though
I can't imagine a highish Q boom box sounding that pleasant.
:) sreten.
Re: Answers to some Q's
fragma said:
Some questions
ryan
I agree totally!, a pressure wave that is so low it cant be heard but felt its incredible, seldom in life do we have a chance to experience and feel infra-waves and the exposures we do get are from jet engines or earth quakes, tidal waves or Hugh thunder bolts cracking the air like Thor’s might Hammer! I can pressurized a car’s interior much easier than an average room for infra-waves and honestly It makes people physically sick, I have not pin pointed the frequency that effects the body in such a manner, as I use a sweeping sine wave from 1Hz to 25Hz that runs from a Laptop, I cant find a subject that is willing to allow themselves to be a ginipig for these experiment, what a surprise, as a long exposure of 30 seconds is needed, but some people can take 3 minutes of high pressure infrawaves, and to the person on the outside that cant hear or feel anything, its surprising to see a person inside the car look terrified! This feeling can last for hours, with real physical symptoms, apparently a tigers roars has infra sound in it and anybody that has had a tiger roar or growl at them will tell you they were terrified!
If you submit plans for this design, I promise to make a working prototype! I have access to as many infra woofers that I need so that’s not a problem for me. The only problem is people actually want to urinate after a short exposure, maybe making this device in a rest room is a better idea,LOL:headbash:
:headbash:
heh, I quite like infrasound, had a setup in my car at one stage that would get ~120db at 10hz (possibly more depending on the accuracy of my mike at that frequency) and I found it to be quite relaxing (would feel sleepy after a while), that's with music containing infrasound though, not pure tones.
Agree with Volenti
Hi again,
I have to agree with Volenti. I have played around with a sinewave generator at university, playing around with a few home amps and speakers purely for fun and experimentation. The pure sine wave although producing a sound, lacks higher order harmonics, i.e. musicallity. Deep sounds from a pipe organ for instance played as quick as any other higher note really warms the soul. I personally would vomit if i tried to listen to a 10Hz signal for as long as i could bear. Thats torturerous endurance tests. My aim was to hear more in the music. In fact a particular song number 4 on Enya's watermark (ill double check that number) i can only listen to for about a minute or two before i have to fwd. It has a continuous low fr that exists throughout the song without letting up, but this is more the exception than the rule.
Re: Blowing over a bottle.....
7V said:
Sorry guys but I still don't know what this design looks like. I downloaded the zip file but it didn't have a graphic. From the description it sounds like a Daline.
Has anyone got a simple schematic?
Coolin said:
I think this is the underlying principle only larger.
I supose thats pretty effecient.
Coolin
Hi Steve
I have not seen this design yet myself, but i will make one if a design is given, modern drive units have much larger cone travel from ones made lets say 30 years ago, this was a limiting factor in the design way back then,IMO I am sure it will be like a Daline or T-line but working on another wave lenght i hope! It should be very effecient, to make infrawaves part of the music. There is nothing more impressive when demonstrating a pair of speakers when a person really has there :bigeyes: opened.
check out the patent link back one page (providing you can do pdf's that is)
quite a comprehensive set of drawings and explainations
There are ten full pages in the patent with lots of detail (I initially missed that ... DOH!)
...from the patent
not entirely convinced it does what it says on the tin
i'd welcome your thoughts on this but first off thanks for the plans Ryan, i've put them on some space if anyone wants them, save hassling you too much eh? - Holliman.zip
right i've done a rough number crunch and i stress this was just a rough one i didn't have the time last night to draw it into a cad program and get the exact measurements
not having the specs available for the specially designed drivers originally used and without mailing wilmslow audio and having to wait for a response i've used 3 different drivers as a comparison (all eminence it was easier) and put it into AkaBak (the only thing capable of simulating this)
anyways i'm not entirely convinced for starters the efficiency wasn't as high as i was expecting and the smoothest line gave a 12dB roll off from 50Hz which could easily be obtained with a sealed box
however the biggest shock and this might explain the poor sound at high volumes was that at 1W the cone excursion was already well over 3mm
now it's quite possible i've made a mistake somewhere but i don't think so having rechecked it this morning
obviously better drivers maybe out there with tweaks to suit but see for yourselves - Holliman Response
black line = Kappa 15LF
green line = Beta 15
blue line = Alpha 15
i think it's possible the theory is sound however the application of it is flawed because of driver limitations namely the excursion and rather than using a low excursion driver a high one might be best ie the lab12 might be a good one
i didn't model it cos it would've meant redoing the whole thing
i might do so later as i'm going to have a play around with the whole design anyways and i'll let you know my results
the other side of this is bar movies and their effects what medium actually produces signals below 20Hz?
i was always under the impression the vinyl was cut between 30Hz and 15KHz with CD's being 20/20
bottom A on a concert grand might be 27.5Hz but i'm not convinced we hear that more than we do its harmonics
if that's the case are people simply feeling nauseous to some humble deck rumble or spurious groove distortion?
dave
I haven't had the time to look into this thoroughly yet but it may be that the Helmholtz resonator theory is close to the mark.
If so, I would guess that unless the box size is large, the Q of the resonator will be high, giving a very steep curve and a precise frequency that is 'amplified'. Either side of this frequency the response won't be so good.
Can anyone go further on the theoretical side of the design?
