All,
I completed the build of my Tubelab SE this morning. Powered it up w/o any tubes and things checked out. I then put my rectifier in (GZ37) and once it started to heat up, R30 gave up the ghost. Any thoughts as to where I should look ? Perhaps Im shorted somewhere ?
Thanks,
Steve
Thanks,
Steve
Ok guys - here's where I am:
When I do not have the 5842's in the amplifier, I get the following voltages on U2/U3:
G: 122v
A: 477v
K: 477v
My unloaded B+ is 477v. Does that appear correct ? Im assuming no - because when I put the tubes back into the sockets (only the drivers and the rectifier are in) I get:
G: 1.02v
A: 477v
K: 268mV
Here's the data sheet for the devices:
http://ixdev.ixys.com/DataSheet/98704.pdf
I purchased replacements, but want to run this past you all before I go ahead and replace.
Thanks,
Steve
G: 122v
A: 477v
K: 477v
G: 1.02v
A: 477v
K: 268mV
Thanks,
Steve
1) w/ no tubes in,
B+ = 0v
B- = 0v. R6 is bad
Output tube filament supply left =4.96v , right =4.96v
2) w/ rectifier tube in,
B+ =474v
B- = 0v. R6 is bad
Output tube grid to ground left = 0v , right =0v
3) w/ rectifier tube and input tubes in,
B+ =474v
B- =0
Input tube plate to ground left =1.2v , right =1.2v
4) w/ all tubes in and set the output tube bias,
B+ =474v
B- =0
Input tube plate to ground left = 1.2v, right = 1.2v
B+ = 0v
B- = 0v. R6 is bad
B+ =474v
B- = 0v. R6 is bad
B+ =474v
B- =0
B+ =474v
B- =0
- More Vendors...
- Tubelab
- Let the magic smoke out of R30
