I made the mistake of having the sound on and my wife nearby when I played that video.
I got into a lot of trouble when liking this turntable from my vested interest friends. It has no arm resonance. It needs a record cleaning machine like the Monks ( or similar , not vacuum cleaner type, nor ultrasonic ) to work properly as there is no stylus to assist. ELP can scan different parts of the groove to find undamaged areas. Imagine Caruso as it was pressed from a low grade disc. Sn ratio is about - 55 db which seems OK, listen for yourself. Personally I find the sound like CD with vinyl easy of listening. Very open. I am told the short comings become obvious when the novelty wears off. I doubt that.
One thing I like is that the stylus drag will not create dynamic wow. Also if direct drive cogging is less likely.
:: Laser Turntable Player - Vinyl and Laser Record Player from ELP Japan ::
Right, seems this issue is very divisive, I'm not going to lose any sleep over it
There have been turntable mats with carbon fiber to decharge LPs, like the DStat mat, that seem to work reasonably well.
Location on sunset is very expensive now . Doug still working at last I checked.Strange , supposedly there's a 6 month back log of work currently for mastering suites ....
How does touching the hot of one coil to the "ground" of the other complete a circuit ? If the coils are separate of each other does any thing happen ? I would have thought a special sweep record would be sold for this purpose with virgin snake oil lub.
Little. Guy raving over S5 , go to second video , playback via RR and TT , good over phones for u-boob ...
Magico S5 Speaker
Listen thru all songs is best ...
Magico S5 Speaker
Listen again its about putting both coils in series ....
Depends on engine r.p.m., George.
Also, on the proportion of bore times troke.
Guy walks into a store to purchase condoms and say to the cashier , let me have 3 condoms ..
Cashier : do you need a paper bag ..?
Guy: Nah , she's a looker .....
I'm glad, he's a very dedicated person. In his DD LPs, he even set levels and then replaced the pots with fixed resistors.
Smart boy ...I'm glad, he's a very dedicated person. In his DD LPs, he even set levels and then replaced the pots with fixed resistors.
Interesting ... tape hiss is surprisingly high - but the aspect that intrigues me is the classic, steady degrading of the SQ as a particular snippet of the track proceeds - same old behaviour as always, but I haven't noticed it so prominently in a system for quite some time - anyone else pick it? It's particularly obvious in the House of the Rising Sun bit - starts off pristine, and gradually gets more murky as that segment of sound proceeds ...Little. Guy raving over S5 , go to second video , playback via RR and TT , good over phones for u-boob ...
Magico S5 Speaker
The SQ variation is so definite it must show some obvious traits - I'm downloading that clip at the highest available rate at the moment, will try looking at, analysing the waveform to see if I can pick something obvious, a telltale signature of the artifact - could prove valuable as a resource for understanding ...
Not necessarily a problem with the RR, in fact pretty unlikely to be - this is more a general system issue, fairly common - I would put my money on the combination of pre and power amp being "most at fault".
The best meds come out of tall bottles, coloured a nice rich red ...
- Member Areas
- The Lounge
- Sound Quality Vs. Measurements
