Just thought I would post this I found on the internet.
Someone might find it interesting..
Run Away Brainz: DIY: How to bend aluminium the easy way with a home made brake and a few tricks
I guess it would work with 1.5/2mm without using a table saw..
M. Gregg
M. Gregg
M. Gregg
Good find!
I have to test it. If I succeed the anyone will!
Nice looking bends.
I'd want to see a close up of the radius produced by these bends. I suspect you'd see stress lines.
And, also, the alloy used will have a large effect on how well this will work.
Someone suggested annealing the aluminum - presumably to soften it - and this might be a plan, especially if a home oven would do the trick. This I do not know.
Would be interested to see what sort of results are obtained by folks here... and to see some closeup shots.
_-_-
_-_-
Nice looking bends.
_-_-
5052 is the alloy used for bending. If you want to minimize cracking you bend it in stages, usually not worth the effort.
6061 is the alloy most folks stock as it is weldable. 3003 is the cheap stuff you can find at places like home depot. Nice and shiny but not very strong.
Now as to a wood bending brake, believe it or not most the the earliest metalworking equipment was made of wood. Next step was to use the wood to make sand cast metal tools. If you think that is ancient history look at any of the large machine tools from the 1940's.
I have a small JET 3 in 1 Brake, Shear and Roll. It is sort of the home equivalent of a bench version table saw.
I also have a few other tools.
Quite an impressive and creative way of working aluminium. Job done without a big radius and probably without tearing on the outer radius. Nice.Just thought I would post this I found on the internet.
M. Gregg
The brake was a father's day present -- they gave me a Grizzly mill one year, a little Delta drill press and some Rigid battery powered tools -- it's a tradition and better than a bottle of Irish whiskey.
My old man has been giving me tools for holidays as long as I can remember being able to use one. Best presents ever.
Now that is one nice tradition... Hope the family continues to deliver stuff that "you" need , are they surprises each time or do you order? Sorry for being harsh but I want to get into the scheme as well
cutting aluminum on a table saw is no biggie. Just use a non ferous blade and be carefull, cut slow and wearing safety glasses is a must. Very noisy
I have cut hundreds of patio stones for the back yard, sheet metal and ceramic tiles all on the table saw with the correct blades.
Man the thought of running an aluminum sheet across my table saw just scares the crap out of me. I've had kick back with plywood and such, but the idea of a sheet of aluminum doing it...... geez......
Cut's great as long as you can keep the blade cool.
I have a Grizzly metal brake.
I have a Diacro 40 ton. That wooden one probably doesn't leave as many die marks though.
So, what is the verdict? DIY or buy a multithousand dollar professional tool as they produce what you expect every time? I believe everyone here is making lesser bends at any time for their diy projects than there are months to the year. So make your pick, a few strain lines or die marks - who cares - and if you do - there are options
I go for the DIY path.
Waste of time and requires a sizable space.
- Design & Build
- Construction Tips
- Aluminium bending..
