Will anyone create some boards we can purchase as a group buy for those of us who don't have the supplies or knowledge to produce or own boards. This looks like a great design that has so much capability and the variation in output power for the three designs should cover any need we may have. I know I would purchase some boards if offered.
This is why I do a V1.2 now.
Prototype ran first time (NAF) ... but we had to make sure.
Many current DIYA projects are having problems now (I WON'T elaborate).
PCB before the "bugs " are worked out .
I DON'T want this !!
The OPS is "good to go" - any takers for a batch o' chinese FR-4 ... I'll
give up the gerbers !
This IS the "cat's meow" for fickle builders who like to build a amp
a month to find the better "sound". you can make this into ANY
DIYA class AB amp.
OS
EDIT --- WOW !!!!!View attachment 401422
Which tests do you want made?
[click on picture to see it larger]
THx-RNMarsh
If I can get some PCB's made , you will get some .
Me, NAF , Bimo ... just have DMM's/oscilloscopes .
PS - step 1 is done , they work and are stable. Step 2 - housekeeping and documentation (and a few more builds).
OS
THx-RNMarsh
WOW The only things you need to add to these are a Time Domain Reflectometer, a 5 Gigahertz 4 channel scope and a CAT-6 continuity tester. WOW
Do you consult for NASA or NSA?
Thanks Ostripper. I can wait for the details to be ironed out and the finished boards with the chosen input section. Another question is could these boards be used commercially without any patent problems if that could be arranged later on?
Final deal - (this weekend)
3-4 IPS's
1. NAF's "NADv1.2" with servo -
He says "wonderful" sound , 1mv offset, runs the OPS bias within a mV.\
I say "good to go" - tiny tweak to layout.
2."HB/wolverine" we KNOW this works - read the Badger thread. "war dog amp"
"good to go"
3." VSSA variant" (I'm doing this now - multitasking) Very similar to the
NADv1.2 - 99.9% chance it will work just as well .... it is a far less
involved circuit - super simple .... sure bet !!
4. I might get to the "symasym" , it also - is one that I have already
built. Another sure bet. (this one is a great subwoofer IPS !!)
This can not beat the CFA's or HB/wolverine THD20 , but has the ONLY
10ppm 20HZ !
(below)
4 IPS's for many applications , all have different "personalities".
PS - NO infringements - my circuits are "bastardized" enough as not
to be like the others. Most designs are hybrids of several designs - ALL
fair game , no "prior art" I will integrate any good idea .
OS
Am I correct to think that some of these are vfa and some are cfa implementations?
2 and 2 - just like the thread states "rumble"...
HB/wolverine and symasym are VFA.
NAD and "CFA-X" (below)are CFA.
CFA-X is dirt cheap ... amazing - 25ppm/90db PSRR /2mv offset - great CFA
"starter amp" .
ALL are 4-5ma VAS's , can be directly swapped out
to the OPS , might not even have to adjust the OP bias.
OS
Wow.. just great! this thread sooner or later will attract more and more DIY builder.
A wonderfull gift from you, many thanks uncle Os!!!
Thank you , NAF. You are a great builder - hopefully , you
will try the new ones.
Don't worry , I will triple check (don't want your nice EF3 to have a problem).
NO "duds" from me !
OS
Yes uncle .. i will try it as this modular design will make an easy and fast build. Thank you very much for your effort and support.
The "Wolv" will my next build..
Yes ! Bimo did the "wolv" , perhaps we can "refine it".
Excellent screen printing - do you spray to make it stick (adhere) ?
OS
No spray, clean the surface with paint thinner, just flip the screen and photocopying it on thin ex sticker paperYes ! Bimo did the "wolv" , perhaps we can "refine it".
OS
On shiny surface. Or use transparant photocopy mica/plastic.
THx-RNMarsh
Oh my god!
Hi Naf sorry for this but i'm confused.No spray, clean the surface with paint thinner, just flip the screen and photocopying it on thin ex sticker paper
Can you tell me in which posts you have take files (pdf) for final version and what modification you have make?
Best regards.
Thimios.
Best regards.
Thimios.
For IPS board or OPS board ?
I ask about IPS and OPS boards .For IPS board or OPS board ?
I see OPS pdf(zip) in post 223
IPS pdf(zip)in post 210
Are these files tested?
Thanks for reply.
Thimios.
- Slewmaster - CFA vs. VFA "Rumble"
