NOS Tube Socket Question
Does anyone have particular experience with NOS (new old stock) tube sockets?
I want to replace a socket in an old integrated amp -- it's contacts are dicey and I want to add a shield because rf is apparently getting in. I have some sockets and shields lying around that I've had for decades.
But -- would I do this whole job and end up having replaced one old socket with another old socket, and gained nothing?
I bought some Cinch sockets at a ham fest that were tarnished. I figured a little flux would take care of it.
It did not. I never was able to get them to solder to my expectations.
Out of maybe twenty purchases of old sockets those were the only ones like that.
Assuming your replacement NOS socket contacts are clean and bright I see no problems. Also assuming you're refering to a phenolic or porcelain style socket and not the old wafer jobs.
As far as the shield goes, it may not help cure the RF problem. And if it's in the RF circuits, don't. You'll detune the stage.
Here is the socket that was bad.
Some of the chinese sockets are junk. Pin retension is poor.
Eastern Block ebay connectors have been top notch.
Sockets I've purchased form Antique Electronic Supply have been excellent.
Socket for what tube??
Use Teflon sockets for less microphonics and better sound quality as this:
US sockets also are bad, stay away of all sockets that use this kind of claw contact, in fact this socket was invented by RCA:
There is nothing wrong with mica loaded phenolic, AKA "micanol". :yes: AAMOF, it conducts fewer vibrations than porcelain does.
The price of those "fancy/shmancy" PTFE parts is high enough to cause severe indigestion. :mad: Also, I've seen reports of builders fiddling constantly to maintain good contact with the tube pins. I'll pass that sort of "boutique" stuff by.
What contact type do you suggest??
There's not much choice, when it comes to 7 and 9 pin miniature sockets. Scan the archives here and over on AA for remarks about "cup" and "fork" contacts in Octal sockets.
JMO, keep the contacts clean and free of corrosion. DeOxit and anhydrous isopropanol are your "friends". If you "roll" a lot of tubes through your equipment, periodically check socket contact tension.
Too bad, no best.
The 6C33 demand much from the socket, even so Russian sockets use glove/lugs types contact:
http://www.gstube.com/photo/2187.jpg
Seems there is no better contact system than this picture.
I agree, sockets that grip the pin tight but have a bit of wiggle room are better.
A stiffer socket would actually cause more microphonics, if anything.
In my humble opinion, I highly doubt a Teflon tube socket would sound "better", whatever that is. If you can provide some evidence I might even be willing to give it a shot.
Vintage style of sockets are still the best in my opinion, brands like Cinch, Amphenol etc.
I don't see why you couldn't use NOS sockets provided you clean them of oxidation where there appears to be any. You can succesfully use dry contact cleaner spray then before it dries scrape the inside of the pin holes with a needle or better yet insert a tube several times that should clean any oxide. And it even works with the antique wafer type sockets, though they losen easily i've had some trouble with those.
For power tubes i would check twice the socket quality. That claw socket Tinitus posted looks awful, at least 2 of the claws are not even aligned.
After seeing what's available for the 833 tube these days I decided to make my own sockets out of Teflon bar stock, aluminum connectors and brass threaded inserts. PITA, but if they fail I know who to blame!
