Ian asynchronous I2S and S/PDIF FIFO KIT group buy
GBV Shipping status Oct.23
Please send the order form back to me as soon as possible if you still didn't, a lot of orders are on hold waiting for the priority
arrangement of the limited FIFO KIT. Thank you.
Please note, the max insurance value for a bubbled envelope is USD60-, have to use box if need more insurance.
Tracking number will be sent to your paypal account if applied.
For those letter mails, please keep your fingers crossed .
Please let me know if your paid more than three days without listed below, or if you paid shipping with traking number but it didn't
show on Paypal
Shipped on Oct. 16:
GBVPCM 09,10,12,13,14,24,36,58,65,79,85,89,92
GBVFIFO 06,34,51,57
Shipped on Oct. 17:
GBVPCM 03,15,37,56,93,
GBVFIFO 02,04,08,15,20,30,19,59,61
Shipped on Oct. 18:
GBVPCM 34,82
GBVFIFO 09,25
Shipped Oct. 21:
GBVPCM 17,19,22,35,43,61,62,77,87,94,95
GBVFIFO 43
Shipped Oct. 22:
GBVPCM 41,45,51,73,78,
GBVFIFO 32,
Shipped Oct. 23:
GBVPCM 18
GBVFIFO 40,46,63,37(#37 S/PDIF board shipped in a separate envolope because of over size)
Ian
GBVFIFO01 : jbercovici : 1x I2S FIFO KIT V3.80, 1x Package of Universal SMT XO Adapters lot of 5, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket,
GBVFIFO02 : Celihman : 1 pcs I2S FIFO KIT, 1 pcs Dual XO Clock board
GBVFIFO03 : APK 1x FIFO KIT, 1x Si570 Clock board, 3x TPS7A4700 Regulator, 1x FIFO isolator, 3x Battery management 1 x s/pdif 1 x I2S backdoor plus
GBVFIFO04 : duster1 : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1x Battery management, 1x I2S backdoor, 1x SMT XO Adapters Kit
GBVFIFO05 : chi0001: bIII adapters pcb x4, tps7a4700 x4
GBVFIFO06 : hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6” double-ended 50 ohm coaxial cable
GBVFIFO07 : malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 2x S/PDIF Interface Board, 1x Finished FIFO Isolator
GBVFIFO08 : mcluxun: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board
GBVFIFO09 : casshan : 1 x I2S FIFO KIT v3.8,2 x Finished FIFO isolator board v2.5,2 x Si570 Clock Board V3.5 (with Si570),2 x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO10 : hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO11 : luisbock
GBVFIFO12 : kazap: 1x i2s FIFO kitv3.80, 1x Dual XO Clock Board, 1x finished isolator, 1x TPS7A4700, 1x Battery management, 1 x S/PDIF , 1 x I2S backdoor KIT, 4x 6” 50 coaxial cable, 1x XO Adapters, 10x SMT U.FL socket
GBVFIFO13 : iskwon: 2xI2S FIFO KIT and 2x Dual XO Clock board
GBVFIFO14 : audiopassion
GBVFIFO15 : ctrange: 1xI2S FIFO KIT V3.80, 1xDual XO Clock board V3.3, 4xSMT U.FL socket, 1x12” double-ended 50 ohm coaxial cable, 1x6” double-ended 50 ohm coaxial cable, 1xPackage of Universal SMT XO Adapters.
GBVFIFO16 : LOBOONE: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x Package of Universal SMT XO Adapters lot of 5, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
GBVFIFO17 : errmoo I2S FIFO KIT V3.80, Si570 Clock Board V3.5(with Si570), S/PDIF Interface Board
GBVFIFO18 : sernikus I2S FIFO + Dual XO
GBVFIFO19 : TonyB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface, Board, 1 x Package of Universal SMT XO Adapters, 1 x PCM1704 board, 1x I2S backdoor
GBVFIFO20 : korben69 : 4 x Bare PCB of TPS7A4700
GBVFIFO21 : Billyk: 14x SMT U.FL socket, 2x 6” double-ended 50 ohm coaxial cable, 4x 4” double-ended 50 ohm coaxial cable
GBVFIFO22 : pavelal: I2S FIFO KIT V3.80, Dual XO Clock board V3.3,S/PDIF Interface Board, 10 x SMT U.FL socket, 8 x 6” double-ended 50 ohm coaxial cable, 3 x 12” double-ended 50 ohm coaxial cable, Package of Universal SMT XO Adapters lot of 5, Finished FIFO isolator board V2.5, 2 x Finished TPS7A4700 low noise regulator board V2.5, Passive Battery Management Board V2.5 Mini KIT
GBVFIFO23 : JustBuildLspkAS: 2 sets with optimize SQ/ minimize board qty for TDA1541 and PCM1704/63
GBVFIFO24 : crobbins5421: 1 x Finished FIFO board, 1 x Dual XO Clock Board, Universal SMT XO Adapters lot of 5
GBVFIFO25 : Iancortez: 4 x SMT UFL socket, 2 x Additional BII adapter pcb, 2 x SMT connector package for BII adapters
GBVFIFO26 : LuisMCP: 4 x BIII Adapter PCB.
GBVFIFO27 : TNT: 1 FIFO board (no clock). 3x Finished TPS7A4700
GBVFIFO28 : clsidxxl :1x I2S FIFO KIT V3.80,1xDual XO Clock board V3.3,1x Package of Universal SMT XO Adapters,1x Finished FIFO isolator board V2.5,1x Finished TPS7A4700 low noise regulator board V2.5,3 x 6" coax cable and 3 x SMT U.FL socket
GBVFIFO29 : Ryelands: 1 of I2S/FIFO kit; 1 of finished isolator board; 1 of Dual-XO Clock board; 2 of finished TPS7A4700 board; asstd cables.
GBVFIFO30 : jcga: 2 x TPS7A4700 finished boards; 3 x TPS7A4700 PCB only; 2 x passive Bat management minikit; 2 x U.FL socket kit; 1 x xoadaptator kit
GBVFIFO31 : canvas: 1 x I2S FIFO KIT V3.80, 1 x Dual XO Clock board V3.3, 1 x S/PDIF Interface Board
GBVFIFO32 : sidiropa:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
GBVFIFO33 : hochopeper: 2 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 2 x finished FIFO isolator, 1 x Si570
GBVFIFO34 : zapio : 1 x Si570 , 2 x finished FIFO isolator
GBVFIFO35 : fregones : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x Si570
GBVFIFO36 : fukinspud : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1xfinished Battery management, 1x finished I2S backdoor, 1x finished SMT XO Adapters Kit
GBVFIFO37 : nedi: 1x FIFO Kit v3.80, 1x Dual XO clock board v3.3, 1X Finished FIFO Isolator board v2.5, 1x S/PDIF interface board, 1x I2S backdoor kit for S/PDIF board, 1x Passive Battery management board v2.5 mini kit
GBVFIFO38 : manolo2001: 2x finished I2S FIFO board, 2x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 2x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570,1x Package of Universal SMT XO Adapters lot of 5, 2xFinished TPS7A4700 low noise regulator board V2.5, 10 x SMT U.FL socket, 10 x 4” double-ended 50 ohm coaxial cable, 6 x 6” double-ended 50 ohm coaxial cable
GBVFIFO39 : Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
GBVFIFO40 : Tony_T: 1x I2S FIFO KIT V3.80, 1x 10P 1.0mm FFC/FPC cables combo, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO41 : Heffa: 1 x Package of Universal SMT XO Adapters lot of 5, 2 x Additional BIII adapters PCB, 2 x SMT connector package for BIII adapters, 4 x 4” double-ended 50 ohm coaxial cable
GBVFIFO42 : curryking 1 x Dual XOClock Board,2 X Package of Universal SMT XO Adapters Kit,1 x Si570 Clock Board V3.5(wuth Si570),1 x Finished TPS7A4700 low noise regulator board V2.5,1 x SMT finished Battery Management V2.5 Mini Kit, 2 x 6" double-ended coaxial cable
GBVFIFO43 : vanwykca: 3 x additional BIII adaptor PCB, 3 x SMT connector package for BIII adaptors, 5 x finished TPS7A4700 low noise regulator board V2.5
GBVFIFO44 : Joonas: 1x fifo kit, 1x dual clock board, 1x spdif board, 1x finished isolator boards, 2x adapters for crystek if you still have them, 1x nos pcm add-on from the other thread
GBVFIFO45 : wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
GBVFIFO46 : _oxygen: 1x FIFO Kit, 1x Si570 Clock Board (with Si570), 2x Finished FIFO isolator board, 1x SPDIF Interface Board, 1x i2s Backdoor Kit, 3x Finished TPS7A4700 low noise regulator board, 1x SMT finished Battery Management Mini Kit, 10x SMT U.FL socket, 6x 4” double-ended 50 ohm coaxial cable, 4x 6” double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x 10P 1.0mm FFC/FPC cables combo
GBVFIFO47 : frd__: 10x Bare PCB of TPS7A4700 low noise regulator
GBVFIFO48 : palmito: 1 FIFO board, 10 PCB of TPS7A4700 low noise regulator
GBVFIFO49 : brettlb: 2 x FIFO board, 2 x Isolator board, 1 x Si570 with Si570, 4 x finished regulator boards.
GBVFIFO50 : davej: 1 x FIFO kit, 1 x dual XO, 1 x finished isolator board, 1 x finished TPS7A4700 regulator
GBVFIFO51 : flowerpot: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator
GBVFIFO52 : Bennyboyvg: 1 x FIFO board, 1 x Si570 board (with Si570), 1 x finished isolater board, 1 x finished regulator board, 1 x additional BIII adapters PCB's, 1 x SMT connector package, 6 x 4" coax cable, 7 x SMT U.FL socket
GBVFIFO53 : Popolvar: 1 x FIFO board, 1 x dual XO
GBVFIFO54 : necplusultra: 1 fifo board,1 x Si570 board (with Si570), isolator board, 5 TPS7A4700 boards
GBVFIFO55 : crowlie: 1x I2S FIFO KIT V3.80, 1x Dual XO Clock board V3.3, 1x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5, 4x Passive Battery Management Board V2.5 Mini KIT, 10x SMT U.FL socket, 8x 4" double-ended 50 ohm coaxial cable, 6x 6" double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 1x 10P 1.0mm FFC/FPC cables combo
GBVFIFO56:curryking: 4 x Dual XO Clock Board,4 x 6" double-ended U.FL cable,2 X Package of universal SMT XO Adapters Kit
GBVFIFO57 : Alcaudon: 1 x Dual XO Clock Board, 5 x BIII Adapters PCB, 3 x SMT connector package for BIII adapters, 10 x SMT U.FL socket, 3 x 4” double-ended 50 ohm coaxial cable, 3 x 6” double-ended 50 ohm coaxial cable, 3 x 12” double-ended 50 ohm coaxial cable.
GBVFIFO58 : ruupie: 1 x FIFO board, 1 x Si570 board (with Si570), 1 x finished isolater board, 1 x finished regulator board, 2 x BIII Adapters PCB, 2 x SMT connector package for BIII adapters, 10 x SMT U.FL socket, 3 x 4” double-ended 50 ohm coaxial cable, 3 x 6” double-ended 50 ohm coaxial cable
GBVFIFO59 : tofurky : 1x finished TPS7A4700 regulator, 2x TPS7A4700 bare pcb
GBVFIFO60 : MarcellD : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1x I2S to PCM converter board
GBVFIFO61 : Marek : 1x Dual XO Clock Board (if available), 1x Finished FIFO isolator board V2.5, 1x Package of Universal SMT XO Adapters KIT lot of 5, 21x SMT U.FL socket, 9x 4"double-ended U.FL coaxial cable
GBVFIFO62 : 4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator
GBVFIFO63 : normundss : 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT, 1x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO64 : Greg Stewart : 1 x i2s FIFO kit
GBVFIFO65 : znarfomat : 1x I2S FIFO KIT, 1x Dual XO Clock board
GBVFIFO66 : Crom : 1x I2S FIFO KIT, 1x Dual XO Clock board, 1 x complete isolator board v2.5, 2 x BIII adapter kit
Help finalising order...
Hi all,
First off, thanks to iancanada for designing the boars and running (with help from his wife I think too) these group buys - very much appreciated! I just need a little help in finalising my order...
I am running a WaveIO connected to 2 x Buffalo IIISE's in dual mono format. I am currently using the Isolated I2S header on the WaveIO and splitting feeds to each DAC board. I thought your BIII adapters looked like they would help to do this splitting more neatly (using u.fl cables) and I also decided that it was the perfect excuse to try out your FIFO project ;-)
I think I need the following:
1 x I2S FIFO KIT
1 x Dual XO Clock board (OR 1 x Si570 board)
1 x TPS7A4700 LNR board (if Si570 is recommended)
2 x bIII u.fl input adapters (1 included in FIFO kit but 2 more needed for other DAC board and the WaveIO header)
2 x u.fl cables for mclk for DAC boards
Questions:
1) U.FL cable: Would it be best to go for the bigger diameter silver-plated cables in all circumstances or is the benefit of the diameter outweighed by the additional length...I know it's best to keep the length as short as possible (which look like they are only available in the thinner cable)?
2) Si570 or dual XO for dual mono Buffalo IIISE? Both appear to offer native dual mono mclk signalling. Can I confirm that this is the case? Also, I'm not clear on what is available/limited at the moment. Are both the dual XO's and the Si570 boards available now as this might influence decision?
3) I'm assuming that I'll only need one clock mounting PCB (as supplied in the FIFO kit) as in dual mono mode only the clock on the designated master DAC board is used?
Many thanks once again,
Crom
Hello,
I discover this project, this really rock ! I want to build a music player with pcm1704 dac chip with raspberry pi as music player, plug with I2S. So it will be :
Raspberry pi =} FIFO board =} Isolator Board V2.5 =} Duax XO clock =} I2S to PCM board } DAC board...
So if i understand my need :
FIFO board
Isolator Board V2.5
Duax XO clock board
I2S to PCM board
PCM 1704 board when it's available ?
I also want to take :
However, if i want to add the possibility to switch between two I2S sources, USB-I2S like waveio and raspberry, do you know if something like this board exist ?
Hi all,
1 x I2S FIFO KIT
Questions:
Crom
Thank Crom you for your order and your questions.
1. The difference between cables is the signal loss. If you don't need long cables, the short silver plated ones are already good enough. But you have to make sure MCLK cables are equal in length for two mono DACs .
2. The Si570 clock board natively supports dual mono DAC, but the dual XO. If you decide going with Si570,please don't forget ordering the u.fl sockets for dual mono I2S signals.
3. If you don't need dual xo clock board to play with different XOs, then yes, you don't need the xo adapter kit, there is already one comes with the FIFO KIT
Another thing I would suggest you is to order two sets of BIII adapter PCBs and connectors, just in case I run out the free PCB comes with the FIFO KIT
Ian
GBVFIFO67 : gugi100 :4x Finished TPS7A4700 low noise regulator board V2.5
Thanks for the replies Ian. Apologies for possibly being pendantic but can I just check that you meant to say that the dual XO board "doesn't" support dual mono? If that's the case, what are the two mclk u.fl connectors on it for and do you know if there's discussion in the thread about the difference in SQ when using the dual XO board or the Si570 board with dual mono?
Many thanks,
Crom
Many thanks,
Crom
You welcome Crom, the second u.fl socket on dual xo clock board was for spdif board. If you want to drive dual mono 9018 from dual xo, you have to mod the PCB by yourself for the secondary I2S output. Please search my previous post for details.
Regrads,
Ian
GBV Shipping status Oct.24
Please let me know if your paid more than three days without listed below, or if you paid shipping with traking number but it didn't show on Paypal
Shipped on Oct. 16:
GBVFIFO 06,34,51,57
Shipped on Oct. 17:
Shipped on Oct. 18:
GBVPCM 34,82
GBVFIFO 09,25
Shipped Oct. 21:
GBVFIFO 43
Shipped Oct. 22:
GBVFIFO 32,
Shipped Oct. 23:
GBVPCM 18
GBVFIFO 40,46,63,37(#37 S/PDIF board shipped in s separate envolope because of over size)
Shipped Oct. 24:
GBVPCM 24a,33(two envelopes)
GBVFIFO 23,33,50,56
Ian
GBV Shipping status Oct.25
GBV will be closed very soon.
If you still haven't sent the order form to me,please send the order form back to me as soon as possible.
show on Paypal
Shipped on Oct. 16:
GBVFIFO 06,34,51,57
Shipped on Oct. 17:
Shipped on Oct. 18:
GBVPCM 34,82
GBVFIFO 09,25
Shipped Oct. 21:
GBVFIFO 43
Shipped Oct. 22:
GBVFIFO 32,
Shipped Oct. 23:
GBVPCM 18
Shipped Oct. 24:
GBVPCM 24a,33(in two envelopes)
GBVFIFO 23,33,50,56
Shipped Oct. 25:
GBVPCM 74,
GBVFIFO 28,52,53,55
Have a nice weekend
Ian
Joined 2012
Order number: ID and quantity
GBVPCM01 : TV Man x 2
GBVPCM02 : merlin el mago
GBVPCM03 : rtd
GBVPCM04 : jameshillj
GBVPCM05 : erin x1 (or 2)
GBVPCM06 : Nikola Krivorov x1
GBVPCM07 : Rupor54
GBVPCM08 : vitalica
GBVPCM09 : analog_sa x 1
GBVPCM10 : andrea_mori x 5
GBVPCM11 : dsavitsk
GBVPCM12 : tagheuer
GBVPCM13 : hirez69 x 2
GBVPCM14 : ccliu x 2
GBVPCM15 : BDL
GBVPCM16 : cddumat
GBVPCM17 : regal x 2
GBVPCM18 : zoran
GBVPCM19 : Jogi
GBVPCM20 : Zen(zenelectro) x 2
GBVPCM21 : Buzzforb
GBVPCM22 : SPWON
GBVPCM23 : crobbins5421 X 2
GBVPCM24 : marcus1 x1 (or 2)
GBVPCM25 : casshan x 2
GBVPCM26 : Dweeb99 X 2
GBVPCM27 : jackw X 2
GBVPCM28 : kazap X 2
GBVPCM29 : danzup x 3
GBVPCM30 : Giordano x2
GBVPCM31 : Tony_T
GBVPCM32 : Tubo x1
GBVPCM33 : clivem x2
GBVPCM34 : noizas x4
GBVPCM35 : JoeyDD x2
GBVPCM36 : skullaudio
GBVPCM37 : dinos8746 x2
GBVPCM38 : dvb-projekt
GBVPCM39 : bisesik x2
GBVPCM40 : guglielmope x1
GBVPCM41 : Valeriano x1
GBVPCM42 : mhgawel x1
GBVPCM43 : av-trouvaille x 1 (or 2)
GBVPCM44 : iloveswan x1
GBVPCM45 : dtses
GBVPCM46 : Flyboi X1
GBVPCM47 : Lil' Knight x1 (or 2)
GBVPCM48 : skippyboy x1
GBVPCM49 : acccruz x1 (or 2)
GBVPCM50 : WhiteBull x1
GBVPCM51 : hksidney x 1
GBVPCM52 : vts2006 x 3
GBVPCM53 : JustBuildLspkAS.x3 &1 fifo kit finished for pcm1704 (ihave AD1862 ,pcm63,pcm1704)
GBVPCM54 : 54: PET-240 2 * TDA1541
GBVPCM55 : TonyB
GBVPCM56 : damohpi x1
GBVPCM57 : iloveswan x 1
GBVPCM58 : Joseph K x 2
GBVPCM59 : mefistofelez x2 (pcm63P)
GBVPCM60 : JLOP x1 (WaveIO, AD1865 NOS SRPP)
GBVPCM61 : sceglar x1
GBVPCM62 : 4me2ctv x 1
GBVPCM63 : tubesguy x 1
GBVPCM64 : ctrange x 1
GBVPCM65 : spm x 1
GBVPCM66 : Joonas x1
GBVPCM67 : Loboone x 1
GBVPCM68 : flowerpot x 1
GBVPCM69 : pavelal x 1
GBVPCM70 : Steve Ha x 1
GBVPCM71 : new2hifi x 1
GBVPCM72 : Superdad x 1 (WaveIO, PCM1704K, discrete I/V)
GBVPCM73 : Greg Stewart x 1
GBVPCM74 : panther5429 x 1
GBVPCM75 : supra x 3
GBVPCM76 : Clsidxxl x 1
GBVPCM77 : Uchi Deshi x 1
GBVPCM78 : kvl x 1
GBVPCM79 : palmito x 1
GBVPCM80 : davej x 1
GBVPCM81 : crowlie x 1
GBVPCM82 : WhiteBull x2 (and one Dual XO Board, in case ones left)
GBVPCM83 : nedi x 1
GBVPCM84 : gonmar x 1
GBVPCM85 : LuisMCP x 1
GBVPCM86 : chansiukwing x 2
GBVPCM87 : tassosk x 1
GBVPCM88 : NATDBERG x 2 (NOS dual differential 2x D20400 project, NOS 384KHz TDA1541A project later)
GBVPCM89 : Jcastellano x1
GBVPCM90 : Marek x1
GBVPCM91 : SVStube x 3*
GBVPCM92 : mksung x 1*
GBVPCM93 : JimS x 2
GBVPCM94 : brettlb x 2
GBVPCM95 : DUC985
GBVPCM96 : ruupie x 2
GBVPCM97 : zapio x 2
GBVPCM98 : Ben Mah x 1
GBVFIFO68: curryking : 2 x 6"double-ended U.FL coaxial cable,1 x Additional BIII adapter PCB,1 x SMT connector package for BIII adapter,2 x Si570 Clock Board V.3.5 with Si570,2 x Finished TPS7A4700 Low noise regulator board.
GBV Shipping status Oct.26
show on Paypal
Shipped on Oct. 16:
GBVFIFO 06,34,51,57
Shipped on Oct. 17:
Shipped on Oct. 18:
GBVPCM 34,82
GBVFIFO 09,25
Shipped Oct. 21:
GBVFIFO 43
Shipped Oct. 22:
GBVFIFO 32,
Shipped Oct. 23:
GBVPCM 18
Shipped Oct. 24:
GBVFIFO 23,33,50,56
Shipped Oct. 25:
GBVPCM 74,
GBVFIFO 28,52,53,55
Shipped Oct. 26:
GBVPCM 47,
GBVFIFO 18,58
Have a nice weekend
Ian
GBVFIFO69: GhostMM : 1xFIFO board, 1xIsolator Board V2.5, 1XDuax XO clock board, 1xI2S to PCM board, 1X10P 1.0mm FFC/FPC cables, 1xPackage of Universal SMT XO Adapters, 1x PCM1704 board when ready
