need a 90 dB 1,5" soft dome
Have you checked the price?
these 35mm domes are highly directive, that is compensated by making the on-axis response rising. Overall this makes the speaker to be too crisp on-axis, a feature that some people like, some don't. The elevated low end makes xo design more challenging
SS
SEAS T35
And Edge simulation of baffle step and diffracions in a typical placement in a 300x800mm cabinet baffle. The SEAS low end is clever - in a baffle the response is straight to 600Hz without xo!
E0055-06 T35C002
EU - 192,00 € https://www.intertechnik.com/Shop/Loudspeakers/Seas-Excel/1768,en,32
EU - 187.80 € E0055-6 - Seas Excel T35C002 1.5 inch dome midrange tweeter - Europe Audio
UK - (?)
X3-06 EXOTIC T35
EU - €285.00 X3-06 (T35) 'Exotic' SEAS [X3-06] - €285.00 : AUDIO-HI.FI, Loudspeaker shop
UK - £275.00 Seas T35 X3-06
Large domes KEF VINTAGE, KEF T15, etc. always interesting: ""A History of Kef Drive Units from the 1960s and 70s."" (link here)
prices...
HI and thanks to all, :)
seas i was thinking that for a seas basic/prestige th e187 euros (each) is very high .. :eek:
to not speak about the exotic... :-(
Navin
I also hav ecosidered audax x34X0, but fs declared ( 700 Hz)is a bit too high and measured tend to near 800 Hz... :-(
cheers
The Sica tweeter looks very nice.
This is a ~1 inch/27 mm (???) tweeter metal dome maybe good for some studio nuts. Is not in the main Seas Catalog on line, as I know it or just couldn't find it (maybe a OEM type reference).
Have fun. :)
The parameter for Sd is: Effective Piston Area 7.6 cm^2.
Seas 27TAFC/G 1,2 inch tweeter - H0883-06
H0883-06 - Seas 27TAFC/G 1,2 inch tweeter - Europe Audio
SEAS 27TAFC-G (H0883-06)
More interesting drivers:
SEAS VINTAGE EXCEL - Seas 29mm tweeter (still available)
Seas T29CF001 - E0038-06 - Sd: Effective Piston Area 8cm^2
E0038-06 T29CF001
SEAS VINTAGE EXCEL
and here:
SEAS Excel Dome Tweeters
Seas T29CF002 E0040-06 - Sd: Effective Piston Area 8 cm^2
E0040-06 T29CF002
SEAS EXCEL TWEETERS
If a 30mm dome is "large" enough for you, I can recommend the Wavecor tweeters, models TW030WA05/06/07/08.
One of these (the TW030WA05) was tested by John Krutke and the results are found in his blog at Zaph Audio:
Zaph|Audio
Just search the page for Wavecor and you will find it.
These have great performance all around and the response is much more controlled and extended compared to the Scanspeak d3806 that you initially mentioned. It can likely work with your 1st order 2kHz crossover and the "05" version has the sensitivity you seek (90.5dB@2.83V 4R nominal impedance).
-Charlie
