LM3886 Schematics + PCB
15Vac+15Vac upto 27Vac+27Vac is usable if you ensure that Vdc <=42V.
If you use lower than 8ohms speakers then the upper limit becomes 22Vac+22Vac
Your 63V capacitors are a waste of resources for an amplifier that cannot operate above 42Vdc.
25V, 35V & 40V capacitors can be used with chipamps, if you ensure your worst case operating voltage is below the maximum for the capacitor you choose.
Can I somehow re-modefy the schematic for 40W max out? My speakers are bass=60w, mid=50w and high=50w. I don't want to damage them, and what power would i need to use then? Thanks for the reply.
There is no need for this. The speakers draw as much current as they need.
You can install a 1000W amp at this speaker and - provided you don´t listen TOO loud, the speakers will be fine. The amps power rating only means the maximum available power, not the one that is used on (normal :rolleyes:) listening levels.
In my opinion, more power recources from the amp are never a bad idea.
However, if you know the impedance of your speakers, you can check the datasheet of the LM3886 and reduce the transformer voltage (and consequently the operating voltage of the chip). So with a given voltage, you only get a certain maximum output power.
But again, I would rather try to maximise the output power for a given speaker impedance, meaning about 20V-22V Transformers for 4 Ohm speakers and about 25V-27V (?) volt ones for 8 Ohm speakers.
My cute little amp....
Thanks Mr. Mile....
The sound is very good and clear, especially paired with my DIY DAC and my super-tweeters. It doesn't run too hot, and I am still amazed at the quality of audio it produces. I definitely recommend building a LM4780 or LM3886 chip amp, you will not be disappointed :)
Here is the amp and DAC:
http://www.diyaudio.com/forums/chip-amps/79303-chip-amp-photo-gallery-219.html#post3119597
http://www.diyaudio.com/forums/chip-amps/79303-chip-amp-photo-gallery-236.html#post3353545
Here are my speakers:
http://www.diyaudio.com/forums/full...ge-speaker-photo-gallery-218.html#post3152149
and here are the tweeters I built to accompany the full range drivers as they lacked a little top end:
http://www.diyaudio.com/forums/multi-way/226786-adding-super-tweeter-full-range-11.html#post3328360
Hi all,
I made the LM3886 in a PCB as per Apex's design with so much optimism but alas! It's not working for me. :( I am lost where I made the mistake.
I powered it up with a 15-0-15 VAC 2 amp transformer . Voltages are okay. But no sound, no hum. Total silent.
Is the IC faulty?
Need your kind suggestion/guidance to make it work.
Thank you.
Thank you so much Port... for your prompt reply.
I double checked the 10k Resistor and pin 8 and the zener diode. All okay as it seems.
Sure, the supply supply is rectified dual with 4700 uF X 4
Very strange. Is there anything more that I should check before changing the Chip?
The circuit is pretty simple, there isn't that much to go wrong. Have you got any voltage at all on the output? I don't use a Zener diode on the mute pin, I simply use a 10k resistor from -ve to it as in the LM3886 datasheet. You could try removing the Zener diode from the circuit and link it with a wire.
.........Have you got any voltage at all on the output? I don't use a Zener diode on the mute pin, I simply use a 10k resistor from -ve to it as in the LM3886 datasheet. You could try removing the Zener diode from the circuit and link it with a wire.
Ohh! I will remove the zener too and report you back with voltages at various pins, in some hours.
Thank you really so much!
