Lowest noise Zener Diodes?
no talk of application specifics? - feeding circuits with any noise rejection at all?
for audio frequencies you may not need low TC or drift, care at all about 1/f - relatively noisy bandgap chips followed by RC filter can be as quiet as needed in many apps
The manufacturers' data indicate otherwise.
Sure enough, Christer's measurements showed much lower noise for the 12V Zeners than those around 6V, while datasheets suggest the opposite. There's an anomaly worth investigating.
Turns out the answer's fairly straightforward - in a nutshell Christer screwed up the measurements.
What he was trying to do was pass a constant current through the DUT, and measure the noise voltage across it. However if you look at his test rig, you'll see that he used a very noisy current source.
So what he was actually measuring was: measured noise voltage = (noise voltage of DUT) + (current noise from CCS * dynamic resistance of DUT), and that second term was obviously significant. Zeners have much lower dynamic resistance at 12V than at around 6V.
Suddenly it all makes sense.
Not suspicious at all. It's max, not typical. "less than 40uV//Hz from 6V8 to 100V" does not mean "exactly the same from 6V8 to 100V".
Exactly, it looks like the test rig for diodes >6V5 was set up with an arbitrary pass/fail limit that gave a good yield and no customers came along asking for a better selection
The error in the old report on diyaudio means that zeners run at a reasonably high current are actually fairly low noise
Well, I can tell you that standard zeners run in starvation mode (low current) are excellent noise sources.That particular problem bit me in the butt one time while working on a HV shunt regulator that used stacked transistors. I thought clamping the bottom transistor with a zener would be nifty, but it turned out a resistor was much (much, much) less noisy due to the low currents involved.
Reverse biased transistor B-E junctions make nice sharp low current 7.5-8V zeners, but I have no idea about how noisy...
Why would a current source made from a transistor (BC549) biased at 1.4V with two forward biasing diodes (1N4148) be considered "very noisy"? :confused:
The power source is made from 9V batteries with decoupling capacitors. The resistor that feeds the diodes is 3.3K, could be made better with additional RC filtering.
