1000W Simple PA Amplifier
Wow.. very expensive MJL****
I Just imagine how the output stage layout of this monster amp will looks like.....if using MJL that's quite heavy....:eek:
This Amplifier is simple class AB design for PA
The driver stage Q9+10 from the darlington power follower consist of the same type of power BjT's than the output stage. Crest Audio uses also this solution for insuring enough current for the output stage in parallel mode.
For me is the question, whether the predriver stage (VAS-Stage) is able to provide enough current to feed Q9+10, and whether the value of 47R for R15 is the ideal choice.
VAS work with 25mA, I want simple circuit without predrivers (TEF).
