#26 pre amp
Joined 2011
Ok. Seems both channels circuits are ok. Now we found the problem, the grid was floating. Always a learning.
Now, the difference might be tube differences, lets measure your current again. Measure B+, over OPTs, 100 R if you want and over 20/15k resistors.
After that, you can plug in scope and measure ripple before and after 20/15k resistors. That can give guidance on how to best drop that voltage without rising the impedance.
Try also what you started with. Some squarewaves thru the circuit.
Another lession learned: Dont ask whats wrong when your circuit doesnt follow posted schematic;). We could have found that much quicker. Right?
Joined 2009
Both tubes measurements
