After my first build, that was a mid size 3 way , with medium quality drivers, I decided to build another set of speakers that will meet my taste in aesthetics,and hopefully in sound quality too.This time the enclosure will be made by a good friend, with exceptional skills both working with wood (MDF) and also with the crossover design.
The first set of speakers were mede by me,and it came out very well, but it was an easier build.
Speakers used:
ScanSpeak D3004 - 660000
ScanSpeak 18W8531G00
ScanSpeak 30W4558T00
The new build is looking like Avalon's Isis,but I used only one subwoofer, and the upper enclosure's baffle (mid/high) is vertical, because I'm using passive filters, and don't want timing problems.
I will keep you up to date with the progress.
Speakers used:
Imus in NYC:
On the work:
Oh- I thought you had these 32W...
Solen Electronique Inc.
The 30W you have is an improved (formerly) Peerless XLS12, and that was also an outstanding performer.
Oh come on! I gotta ask "WHY!?" now.... I see a BG Neo3, but what mid?
Later,
Wolf
Later,
Wolf
Later,
Wolf
Why or what? I know abaout that Peerless, the mid was a SBAcoustics SB17NRXC35 , an inexpensive driver,but it outperformed it's price easily.
Progressing:
Yes, it's an aluminium tube,I had the same resonating sound from a plastic tube ,only noticeable al very low frequency ,generated with a tone generator.I see Xavian also is using aluminium ports, so I don't know what to think, I was thinking the more rigid ,the better .
Thank you for your advice ,I will take this aspect into acount ,and will try to make some tests, before glue-ing the front baffle...
The port placement is not ideal too, direct coupling with the woofer ?
Not really recommended.
Thank you for your post, we can always learn things, can you please talk a little more about this...
And if there is a problem with aluminium tubes please argue, if I will hear resonances I will aply somting antiresonant like Dynamat, or change the material.
PSthe woofer will not touch the port tube phisically...)
I can't justify this mathematically but understand when the source is too close the resonator, i call it "direct coupling", the mass of air in the rest of the box is not take into account. It is a short circuit of the rest of air in the box. Your bass reflex should not work well.
That's all, i can't explain more.
The metal tube is from Geralfino's experience, difficult to justify or argue.
The bass reflex tube is noisy at high frequency (800H-1K), it can stimulate tube frequency. You should choose it with a large diameter.
- Imus - 3 way build with ScanSpeak drivers (large)
