And one more for me:
1. 1 x audiodesign ( DAC base )
2. 1 x quanghao ( DAC base + DAC chassis + transfomer)
3. 1 x fansipan ( DAC base + DAC chassis + transfomer)
4. 1 x yildiray ( DAC base + I/V opamp)
5. 1 x danny_66 ( DAC base + I/V opamp)
6. 1 x MihajloTM ( DAC base + I/V opamp)
7. 1 x i2k ( DAC base + I/V opamp)
8. 1 x axeexa ( DAC base + I/V opamp + OP + tranfomer)
9. 1 x sipo75 ( DAC base + I/V opamp)
10. 1x Jinkslynx ( DAC base + I/V opamp + OP + tranfomer + chassis)
11. DAHL75 ( DAC base )
12. 1 x smoothquark ( DAC base + I/V opamp + OP +/-transformer +/-chassis)
13. 1 x CeeVee ( DAC base + transfomer)
14.1x Smthgbrrd (DAC base + I/V opamp + OP + transformer )
15. 1 x larslang (DAC base + DAC chassis + transformer)
16. 1 x linuxfan ( DAC base + DAC chassis + transfomer)
17. 1 x randytsuch (DAC base)
18. 1 x claudio52 (DAC base + DAC chassis + trasformer).
19, 20. 2 x danielkol (DAC base)
21. NicMac (DAC base + DAC chassis + trasformer).
22. 1 x gjorgji (DAC base + I/V opamp + transformer + chassis)
It seems a very good project. I searched something based on ESS, I think I found it. I need AESBU and balanced outputs mostly, but to have extra inputs as this DAC is a nice plus. Therefore, if it is not too late.
23. myfavoritething (DAC base+ I/V op + OP +chassis + transformer)
And count me in as well!
24. MattMax (DAC base+ I/V op + OP +chassis + transformer)
HI!
I use paypal
thanks
Hi quanghao,
I know you use paypal,but I don't know how to use paypal,is that use you payapl web site to key info to pay right?
https://www.paypal.com/it/cgi-bin/w...737ba21b081989ce41f911b8b0f9abd5cb813489264cd
please kindly and detail how to use your paypal,thank you.
I hope I can still enter.....
25. bertchai (DAC base + I/V op + chassis)
Just edit my user ID :
7. 1 x i2k92 ( DAC base + I/V opamp)
When the production will start ? I hope more participants = less price
26. kimgiin (DAC Base)
Sorry more questions:
1. when will you have a photo of the final chassis? I am very interested and also wanting to get it with the chassis if it finishes nice.
2. If I have a 95mm diameter toroidal transformer, with it fit inside?
Many Thanks
it is, i can help you now.
Is the OFFset output sitting at AVCC with respect to GND (i.e. @ 3.3V)?
yes!
I can change the clock to SAW type later right?
yes, you can do it if the clock
100Mhz wit 4 pin , and run at 3.3V.
thanks
So I understand it takes work to figure out pricing, you need to go ask for quotes and figure out your costs, etc.
But the current pricing is based on a min order of 20.
Since it now seems likely we will hit at least 30, which is a 50% increase, do you think the price could go down at 30? 40?
It seems that now that the group buy is a go, looking at the past few days, the group buy is gaining momentum.
I think if you could lower the price based on higher quantities, more people would sign up, and everyone wins
Please consider this.
Randy
Randy
27. misterrogers (DAC Base)
+1 on Randy's comment above.
Any further news on the price of chassis ? I do really like the chassis but just a few questions:
1. I would like to incorporate a cubox module (SolidRun - Home of the CuBox) within the chassis to have a music streamer - I am not sure if there is sufficient space (rought 55 x 55 mm required)
2. Is there any chance to customise the backplate (more cutouts for other connectors)
3. Is there a possibility of buying matching chassis for a mini-itx motherboard and amplifiers?
A really silly question - if I get my own chassis (modu), how do I mount the LCD to the front panel, or the boards to the base ?
Thanks.
Thanks.
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
