Tubes
Gates 833a for display, not working? No way to test $5.00
Raytheon Type BH globe. Stamped 1939. Cold cathode rectifier. Unable to test? $5.00
Caps
Old TRT Wondercap 3uf 425 Vdc $3.00
.012uf 1200v vintage Mica Large chassis mount postage stamp $2.00
.001uf 1200V vintage Mica Large chassis mount postage stamp $2.00
Transformer
PK-31 SE OPT 5K/8 ohm 5W $5.00
SPK Stuff
Audax DW50m Tweeter w/wedge mount, 4 ohm 94db. $20.00pr w/tilt mounts NOW $15.00
Blaupunkt P652c 2 way coax 6.5” 4 ohm, 91db 65 to 20Khz 40W NIB pr $15.00 NOW $10.00
EV FS-1950 spider for 15” $3.00
EV VC-9200 voice coil for 15” $3.00
EV SR-15 basket gaskets pr $1.00
EV DC7172 dust caps 2.75” $.50 ea or 10 for $3.00
Waldom AA-78 spk cement 1QT NIB (can) $4.00
Waldom AA-76 spk cement 1 QT NIB (can) $4.00
Books/Mag
Electronics Magazine May 1943 and March 1944, great collector’s items. $4.00 NOW $2.00
Radio Physics Course by Alfred Ghirardi, 1933 2nd ed. This has it all, tube, transformer theory $6.00 NOW $3.00
Other Stuff
Distech Silver Plus Interconnect, 3’pr $20.00
Pioneer SX60 amp section, 60W/ch, Xfrm, caps, running, works great. $10.00
RCA PR8065 5 disc CD changer $15.00
Iwill KA266 mother board w/ AMD Athlon CPU 1 Ghz, 512 mb, PC100-DDR ram, Radeon 7500 PCI video bd (CRT-DVI-S Video out) and I/O magic 56K modem. All working $5.00ea or 4 for $15.00
Powork PW450 computer PS 450W $8.00
Kodak Zi6 HD camera $40.00 obo
Guitar Parts...send for list.
Caps
Transformer
SPK Stuff
Books/Mag
Other Stuff
More Books
Thordarson Tru-Fidelity 1961 product catalog. Transformer specs, tube circuits. Photocopy, large $2.00
RCA Transmitting tube book. Photocopy, large $2.00
Transformers
Tomiko OPT-SE 09 rev 2. 0-3.5-5K/0-4-8 ohm, 12 watt -18 watt max, DC 165ma max, used (4 hrs maybe), exel cond, uncut full length leads. (see eBay for description, new $45.00) $30.00
Transistors
Phase Linear XPL909 (3), PL909 (2), SPD164 (2). $7.00 set
RCA 66546 (7703) (2) $2.00
SPK
Mylar Done Tweeter, .75” 8ohm, 92db, 50 watt. Purchased from MCM p/n P11028 $10.00pr
Other
Magnavox DVD Model MDV456/17 $5.00
Harmon Tech DVD Model 202 NIB, never opened or taken out of plastic. $5.00
Cleaning out workshop, more items to come.
Transformers
Transistors
SPK
Other
Capacitors
Oil/paper
GE Pyranol 50uf 330vac $15.00, 20uf 330Vac, $10.00
Captron Type III 27uf 700Vac (2) $10.00 ea
Philco 10uf 600Vdc $6.00
Sangamo 8uf 600Vdc $6.00
Sprague 8uf 1000Vdc $6.00
Pyramid 8uf 600Vdc NIB (3) $7.00 ea
Micamold 6uf 1000Vdc $5.00
Unmarked 6uf 600Vdc $4.00
Cornell-Dubilier 2uf 1000Vdc $3.00
Lot deal $50.00
Oil/paper
Lot deal $50.00
Transformers
Altec/Lansing 1200Vav 150mA +, Bias tap, 6.3Vac, 5Vac. Large(heavy) matched pair out of Simplex theater amps. $30.00 pr
30038-2b 600Vac CT 100ma, 6.3Vac, 6.3Vac, 5Vac $10.00
MTcg 5C171 600Vdc 60ma, 6.3Vac, 5Vac (2) $10.00ea
T849-115A 800Vac 125ma, 6.3Vac, 5Vac $10.00
Stancor P4089 6.3Vac 6 A $8.00
Stancor P4019 6.3Vac 3A $5.00
Choke
HP/Paeco 6H, 125ma (2) $10.00 ea
Other
Aiptek T20 Pocket Cinema, 640 x 480, 8 ANSI Lu, usb. Only used once. $20.00 obo
Choke
Other
Glad you got them. The holiday shipping season is in full swing, and you never know when something may get lost. I seem to lose something each year.
MORE ITEMS
Lambda Model 28 tube regulator, 200~325 Vdc 100mA, 6.3Vac 5A. Fully functional w/tubes $100.00
Simpson Series 55 DC amp meter 0-25ma range #55F-1570 on box. NOS $10.00
MORE ITEMS
More Items
ICs
AD711an $3.00 ea (4)
AD712an $4.00 ea (4)
AD744an $4.00 ea (4)
AD797an $ 10.00 ea (2)
MosFets
2SK405 Real vintage 80’s Toshiba (4) $10.00 ea
2SJ115 Real vintage 80’s Toshiba (4) $10.00 ea or $70.00 for all
2SK135 Real vintage 80’s Hitachi (4) $8.00 ea
2SJ50 Real vintage 80’s Hitachi (4) $8.00 ea $54.00 for all
Transformer
Hammond PT125se 15W/80ma used only for prototype, uncut leads $35.00
TT
AR spring set $5.00
BluePoint needs stylus ($100.00 trade in value at Needle Doctor) $25.00
Constranied Layer Alu/Delrin/Alu sandwich, great as TT arm mount, tube chassis top plate, etc. Custom cut to size, max width is 8”, max length is 19”. 6X6 $5.00
DIY oak arm tube 7” $5.00
Other
Distech Silver Plus interconnect, 3’ pr $25.00
DIY 1/4”Copper Foil/Teflon flat interconnect w/ HQ Gold RCA 3’ pr $15.00 (worth that in RCAs)
DIY 1”Copper Foil/Teflon flat speaker cable 6’ pr. $20.00
Trades Wanted
OPA2134, LM4562, 1578melz, 45, one old style TRT Wonder Cap 3uf, Cardas tone arm wire.
ICs
MosFets
Transformer
TT
AR spring set $5.00
Other
Trades Wanted
