With my limited resources (Asus Xonar DG card--usable as per ARTA ) and even more limited understanding, this is what i got (see attached -- had to do some crazy formatting to get within the limit).
No i havent listened to it & i dont have golden ears (but) i do have 1 channel without P3 (i'll need to measure that) and see whether i can hear any difference in between the two
Very good Kroyin. You are going to have fun.
The CURSE!
indeed damn. I WANT A CNC and a garage to put it in
alu without costing me $1000 (no heatsinks incl.)
Is Aluminum that expensive in Norway ?
(as reference : for that amount, I get ~250lb, cut to size, with protective foil if so desired)
no. but the cutting work is. i have to get a better price on the cutting.
this is about 60lbs.
Get a tablesaw. Piece of cake.
nope. it is mm presision. and CNC of logo and such. only CNC and laser cutter can do this job.
and there is some bending too.
Require special blade ....
- F5 Turbo Builders Thread
