Hi guys!
I need a good stepper attenuator.
Preferably more than 23 positions, with non-metallic resistors (better carbon or wirewound).
I have just tried a chinese audiometric.com but it broke immediately.
Not Elma unless it's already mounted, even only 23 positions. And not DACT.
Please if possibile better ladder type 50KOhm stereo logarithmic.
Thanks.
Thanks.
Acoustic-Dimension, high-end audio and components for tube audio
potentiometers, switches and attenuators homepage
http://www.percyaudio.com/Catalog.pdf page 14 PDF TKD stepped attenuator
http://www.khozmo.com/
Good luck.
Good luck.
Micheal Percy stocks a 45 position 2 deck Shallco switch. The Shallco part is physically huge.
Wirewound resistors are metallic. Carbon film parts require hand matching. Non-metallic, non-inductive, and 1% tolerance are what you get with Caddock resistors.
Perhaps a good off the shelf volume control, with an "infinite" number of positions, is what's needed. PEC hot molded carbon parts match that description and they are reasonably priced.
http://www.ebay.co.uk/itm/Valab-23-...mplifier_Parts_Components&hash=item416fded76b
Anything wrong with this Valab one? It's a ladder type (2 resistors at a time). They also have a SMD one with Vishays, but don't say if it's ladder. Anyone tried these two?
Valab 23 Step Attenuator Potentiometer 100K Stereo Log | eBay
Thanks to all!
I have found interesting the 41 position Shalko but it's not clear what type of resistor they use. I hope not metallic. After the 46 positions square at 179 with Cadoc resistors seems very good, maybe the best.
What do you think? Who is the best?
Bye!
Bye!
Thanks to all!
Bye!
SMD 1% non inductive metal film
Curious why not Dact?.
Really I don't like SMD resistors, and I have heard rumors that Dact is a bit fragile.
hi guys, no one of you kind people can indicate toi me a program to calcolate the value of the resistoirs for a stereo 590 kohm series tyoe?
cheers and thanks in advance
I would use Microsoft Excel.
There is an Excel program available here:
DACT Attenuation Curve Calculator
That appears to do what you want.
- Design & Build
- Parts
- Step Attenuator
