Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Including Si570 clock board interesting list into GBIV waiting list
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
5. AR2 2 x Si570 clock board - definitely!
6. wktk_smile
7. hirez69 1 x Si570 clock board, 2 x Isolator board, 4 x TPS7A4700 reg board, 2 x Battery management board
8. CeeVee - you bet!
9. number9 Si570 Clock Board
10. analog_sa - GB maniac
11. edbk
12. atom6422
13. misterrogers 2x Si570 clock board - Of Course!
14. NicMac - as usual!
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
23. Greg Stewart (also of course!)
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
36. DUC985
37. rsotirov 1x Si570 clock board
38. kvl 1 x Si570 clock board, 1 x Isolator board, 1 x TPS7A4700 reg board, 1 x Battery management board, 1x 1.0mm FFC/FPC cables combo, 1 x back door kit.
39. bkdog
40. necplusultra
41. Nikola Krivorov X2
42. nvduybom
43. Popolvar - 1x Si570 clock board, I will specify the rest of my shopping basket later when the final Si570 board spec is ready.
44. TNT
45. sidiropa 1x Si570 clock board, 1x isolator 1x 1.0mm FFC/FPC cables combo, 1x battery management pcb
46. leejh
47. Alcaudon
48. sernikus (all + 2xSi570 )
49. enantra
50. Giordano, FIFO kit + a dual osc.
51. oyvind I2S FIFO KIT, Si570 clock board, S/PDIF Interface Board, I2S backdoor KIT for S/PDIF board, BIII adapter PCB, SMT connector package for BIII adapters, FIFO isolator board V1.5 MINI KIT, battery management pcb
52. duster1 1x Si570 clock board, 1x isolator
53. Blitz Si570 clock for dual osc. (two needed ?), 1x isolator, 1 x TPS7A4700 reg board, 1 x Battery management board, 1 x back door kit.
54. Josoeff 1 x FIFO kit and 1 x S/PDIF interface board
55. crobbins5421 1 x FIFO kit, 1 x S/PDIF board, 1 x Si570 Clock Board
56. Regal 2 x Si570 clock for dual osc, 1x isolator, 1 x TPS7A4700 reg board, 1 x Battery management board, 1 x back door kit.
57. aos FIFO kit, dual xo clock, S/PDIF board, 1 x Si570 clock, 5 x U.FL socket, 3 X 6" U.FL cable, 1 X I2S backdoor kit, 1 X SMT XO adapter, 1 X BIII adapter, 1 X SMT conn for BIII, 1 X FIFO isolator, 1 X cables combo
58. dvb-projekt 1x FIFO Kit, 1x Si570 clock kit, 1X Isolator board kit, 1x S/PDIF interface board kit, 1x Backdoor Kit
59. Tubo 1x si570 clock kit, 1x isolator board, 1x tps7a4700 regulator board
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
36. DUC985
39. bkdog
40. necplusultra
41. Nikola Krivorov 2 x Si570 clock board, 3 x I2S to PCM board, 2 x TPS7A4700 reg
42. nvduybom
44. TNT
46. leejh
47. Alcaudon
49. enantra
Crystek CCHD957
Need help with new crystek cchd957,
First of all, many thanks to Ian for this great product.. huge improvement to my system, im using a shigaclone for transport and without the fifo, the shigaclone sounds muddy. All i can say is that , the fifo withe generic xo greatly improved my system.
Now i installed the crystek clocks using the adapters, and it doesnt work anymore. output led and lock led on the spdif boards does not light up. If i install back the generic clocks, they work again..
Is there something that i have missed on the instructions?
Will post pics soon..
Thanks guys
I had just the same - in my case some heating on CCHD helped (i used smd rework tweezer to heat on soldering points about 20-30sec.) and it begin working... But i bought second one .....:)
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
36. DUC985
39. bkdog
40. necplusultra
42. nvduybom
44. TNT
46. leejh
47. Alcaudon
49. enantra
60. bisesik 1xI2S FIFO KIT, 1x Dual XO Clock board (Si570), 1 x S/PDIF Interface Board, 1x I2S backdoor KIT for S/PDIF board, 2x FIFO isolator, 1x Battery management board
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
13. misterrogers 1xI2S FIFO KIT, 2x Si570 Clock board, 1x FIFO isolator, 1x Battery management board
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
36. DUC985
39. bkdog
40. necplusultra
42. nvduybom
44. TNT
46. leejh
47. Alcaudon
49. enantra
Updated my item.
There where no rubber o-rings in my delivery. Is it a deliberate choice to exclude them? Pointers to suitable?
When on the topic, what resonance freq. are you aiming at? Has anyone experimented with stiff resp. soft ones?
The o-rings I sourced were not very good. So, I do not supply it any more since GBII.
I'll leave this part to other members. Just hope some one can do more research on this issue (mechanical related jitter suppressing) to find out which is the best suitable one.
Some related posts were in the R&D thread.. But not the finial solution. Just search them if you want.
Ian
I feel it needs to be mentioned, the Si570 multispeed clock board...does multiple speeds...
you only need 1 x si570 clock board
the fact it does multiple speeds, thus does the job of a dual clock board and more; is the entire point of it, otherwise you would be better sticking with the dual clock board.
in fact if you do not need 352.8/384khz audio, you would still be better with the dual clock board with the crystek or NDK clocks
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
36. DUC985
39. bkdog
40. necplusultra
42. nvduybom
44. TNT
46. leejh
47. Alcaudon
49. enantra
61. BDL 1 x Si570 clock board, 1 x Isolator board, 2 x TPS7A4700 reg board, 2 x Battery management board
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
36. DUC985
39. bkdog
40. necplusultra
42. nvduybom
44. TNT
46. leejh
47. Alcaudon
49. enantra
62. damohpi 1x FIFO kit, 1x Si570 kit, 1x isolator kit, 1x spdif board kit, 1x backdoor kit
Adding my purchase
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
36. DUC985
39. bkdog
40. necplusultra
42. nvduybom
44. TNT
46. leejh
47. Alcaudon
49. enantra
63. Overkill Audio - 1xI2S FIFO KIT, 2x Si570 Clock board, 1x FIFO isolator, 1x Battery management board
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
36. DUC985 1x Si570 clock board, 1 x TPS7A4700 reg board
39. bkdog
40. necplusultra
42. nvduybom
44. TNT
46. leejh
47. Alcaudon
49. enantra
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
39. bkdog
40. necplusultra
42. nvduybom
44. TNT
46. leejh
47. Alcaudon
49. enantra
53. Blitz Si570 clock, 1x isolator, 2 x TPS7A4700 reg board, 2 x Battery management board, 1 x back door kit, 10 clock adapter for dual clock (2*5), 2 BIII adapters, both sides, 6 4" FL cables.
Only an update on my order...
One question...meant friendly and not to try to pressure as I really appreciate your great work and effort and being thankful for this...is there a schedule for the clock module to be out ? Obviously we all hold our breath here...
Blitz,
If everything is on schedule, it would be at the middle of next month.
I'm already testing on the pre-production version now.
Just cross my fingers :)
Ian
GBIV
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
39. bkdog
40. necplusultra
42. nvduybom
44. TNT
46. leejh
47. Alcaudon
49. enantra
64. JoeyDD - 1x FIFO kit, 1x Si570 kit, 1x FIFO isolator kit, 3x U.FL 6" cable
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
39. bkdog
40. necplusultra
42. nvduybom
44. TNT
46. leejh
47. Alcaudon
49. enantra
65. chi0001 - 1x Si570 clock board, 1 x TPS7A4700 reg board
