Paradise Builders
Thanks, I will try it/this (and some variations) (this evening) and report back.
Here are some, preliminary, results.
After some experimentation:
V(tst1) Uncompensated CVS+CCS (left schema)
V(tst2) Compensated CVS+CCS (2nd schema)
V(tst3) Uncompensated CVS+CCS+Shunt (3rd schema)
V(tst4) Compensated CVS+CCS+Shunt (2nd schema)
V(n001) Input voltage.
The V(tst1) track shows some ringing, this may lead to oscillation (especially on a very noisy mains). 1st-ring about 8Mhz 2nd-ring about 4Mhz.
The V(tst2) seems well dampened.
The complete standard Paradise PSU, V(tst3) performs excellent, but one should consider that this is a simulation. Placing real world components on a PCB and connecting an actual power source will have its, negative, influence. The complete compensated Paradise PSU, V(tst4) performs excellent also, the compensation as added in the attached schema, e.g. Cc1=470pF and Cc2=2.7n has no real impact in the functioning of the PSU.
As I’m sure that this is not the final word on compensating (when the PSU oscillates (and if)) we have to wait what kind of results compensation gives on the currently misbehaving PSU’s.
So if we use the prereg, we can be sure to minimize or null any oscilation possibility right ?
No, that is not what I said :) Using the prereg removes one possible source of 'agitation' that may start oscillations. The most common source of 'agitation' is the internal noise of the (any) circuit and that cannot be removed.
But, if your PSU is not oscillating (as most) then there is no need to compensate.
BTW this (self-agitation by internal noise) is a good argument to use high quality, low noise, components in every/any circuit. Some times (but not all times) you can spot problems by running the simulation in high resolution (10nS or smaller step size) with no AC signal sources attached. If you look at the FFT of this analysis you may be able to spot potential problems.
In case anyone remembers my old complains that the Paradise will burst into oscillation when shorting the input, or at least something resembling oscillation - this is now completely gone. Apparently shorting the input was feeding ground noise, i.e. the now missing 7MHz into the inputs.
