Canned Crossover Design - What Next?
This started on the Full Range page; TB W5 8ohm driver. Guitar and Bass strings sound great but lacking high end, especially with coat of silicon.
Trying to lean a bit about xo's - very intriguing. I've always known enough to call Madisound, if I wanted something that worked properly.
Lots of on-line ox calculator sites, Second order Butterworth looks straightforward. I can see why some say to use same impedance drivers (tweeter on right is 8ohm, so is woofer).
I did have enough parts to listen to them; xo as shown.
Where do I go from here?
Some box construction plans here:
http://www.diyaudio.com/forums/full-range/219785-w5-1611-saf-sequel.html
Just another Moderator
Joined 2003
Ok where to start. The first thing to learn is that text book xo will almost never be right. Measure the impedance of the drivers in the cabinet! Second it is the acoustic slope that matters not the electrical.
Check out the excellent sticky. Designing without measurements for a good grounding!
Tony.
I might be able to get a buddy to help measure the impedance (tomorrow)
So far some songs are sounding very nice. However the woofer is not rolling off at 2200hz, still going to 3500hz or so. (I didn't think the woofer would roll off easily)
The tweeter roll off is close, however to loud.
L-Pad (now) R1= 1.0 ohm R2= 50ohm
Joined 2003
Based on the spec sheet http://www.parts-express.com/pdf/264-898s.pdf , it looks like the woofers have an impedance of around 10 ohms at 2200 and have risen to around 14 ohms by 20Khz.... did you do your calculations based on 8 ohms nominal impedance?
Some impedance compensation will probably help (if you don't have acoustic measurements and simulation capabilities).
Also it looks like the woofers FR starts rising at around 1Khz and is about 5db hotter at 10Khz. factor in baffle step as well and you could be around 9db higher (on the TB) from about 3Khz up than you are from 100 - 1000 Hz!
Tony.
Joined 2003
ok that doesn't have the same rising response, but the impedance is even higher than 10ohms at 2200 :) It's a bit hard to see on that graph exactly what it is though, since it seems to be a log scale on the impedance, and the lines don't match up with discreet impedance values. If you can get an actual impedance measurement that would be best.
Tony.
Bought them to the "good room"; better but there is a RRRRRR sound in the midrange.
The chart is hard to read, I'm thinking the impedance is around 13ohm.
Went to a on-line Zobel site - for idea what I need.
Dissi thanks!
I was busy this morning and made up new 1.1 coils. HUGE improvement in middle - however still needs work.
Btw, the tweeter L-pad is just cracked open 1/16 of a turn and tweeters are just wailing away :confused:
The bass is crazy nice!!!! they have potential if the xo can be resolved and/or buy different tweeters. [they are old but working/clear]
* the volume is not turned up much on pre-amp either, just a bump i.e. plenty loud.
I'm not sure where that plot came from - that's what the bass curve looks like - exactly!
The box is tuned to 51-52hz.
I went and looked at a 3rd order Butterworth circuit, typical it has two coils, so a little confused there.
I had a pair or clarity caps 3.9 (vs. 4.7uF), so slipped them for the tweeter(s) - a whole sweeter!
I added wire to the 1.1mh coils, now 1.5mf and added the 12uf cap.
Much better - the woofers were overbearing, now much quieter.
I'll find somebody to measure the response - I'll get there someday also :wchair:
added construction pic.
The baffle step causes a rising frequency response in the midrange and demands a larger coil to compensate. According to a simulation 1.5 mH and 12 uF could work. The target function is a 3rd order Butterworth low-pass filter having -6 dB at 2.2 kHz:
Joined 2003
That is an option, but maybe you should wait till you can do some acoustic measurements of your own and see what you can come up with. You are on the right track, so if you keep it up I'm sure you will at the very least learn something, and hopefully come up with something that you are very happy with as well!
Tony.
