.. I am self trained to still hear differences in audio products that may, in fact, be subtle, and little use to many others. I started off in life better at this than most ...
Shame you never did any Blind Listening Tests to confirm these rare virtues.
We fear you Lord JC.Not the appearance of the product, not the advertising of the product, and not the promotion of me associated with the product. I learn from my mistakes, and I am here to advise others to avoid my mistakes that I have made in the past.
None hath the promotion of self to such a Holy degree.
Pavel, got anymore details of your tests? I take it you mean (and used) an ABX box.With experienced listeners, we have very high score in dbx tests mp3 (256kbps and more) vs. original.
Not wanting to take sides in this affair with all the heavy hitters but just like to point out ... the people who know MOST about aural perception are the evil inventors of the compressed formats and they are still learning.
You can see this in the improved performance of the latest formats like evil MP4 compared to evil MP3.
Half an hour into 2013 here.
Happy New Year to All
George
HAPPY NEW YEAR 2U2 !!
Just like the Bybee Quantum Purifiers.We made it! After the Mayan prediction, now we wait for the big earthquake! '-)
JC, there are degrees of 'PERFECTION'. You may like to quiz the evil inventors on how to measure this but here is a very similar & pertinent analogy.How can you improve on PERFECTION? I thought that MP3 was virtually perfect. Gee, I was also told the same thing about CD audio.
Though all your designs are PERFECT, it is likely the level of PERFECTION of most of them would be insufficient to distinguish them from an evil 4558 device in a Blind Listening Test.
However, Blowtorch is so PERFECT that IMHO, some true golden pinnae will be able to reliably tell the difference in a Blind Test.
Then we can ask them whether "Blowtorch sounds worse than an evil 4558 device."
My designs approach 'perfection' because I strive to make them that way.
For example: Just this week I decided to make a BLOWTORCH line amp board model.
To do this, first I have to put the resistor matrix in. The resistors are already specified as to their part #'s and respective bins. It took 2 hours to stuff the resistors, and another 2 hours to check, rotate (for direction, in order to read them properly later), and finally solder them in. Total cost: labor $100, and the raw board cost $50, resistors, maybe $10. Quite a bit of money for an almost bare board isn't it? Now for the active parts and finally the caps.
Money ?The treble unit was a 19mm 'soft' dome from a material that is now sadly Unobtainium.
Don't we all strive to the same ?My designs approach 'perfection' because I strive to make them that way.
How can you improve on PERFECTION? I thought that MP3 was virtually perfect. Gee, I was also told the same thing about CD audio. '-)
Why do you keep telling the same false story? Or do you actually have a cite? How does it benefit you to mislead people?
It may be that ALL sources in the known universe are so poor that Blowtorch ALWAYS sounds worse than evil 4558.With inferior sources and loads, the Blowtorch could in fact sound worse than a 4558, that is bandwidth limited on purpose.
Truly hand carved from solid Unobtainium by v****ns.To do this, first I have to put the resistor matrix in. The resistors are already specified as to their part #'s and respective bins. It took 2 hours to stuff the resistors, and another 2 hours to check, rotate (for direction, in order to read them properly later), and finally solder them in. Total cost: labor $100, and the raw board cost $50, resistors, maybe $10. Quite a bit of money for an almost bare board isn't it? Now for the active parts and finally the caps.
Though I hesitate to pontificate on our Lord JC's virginity, his virgin birth is beyond doubt to all true BELIEVERS.
What do you want to put in front of CDs ? Vinyls ?How can you improve on PERFECTION? I thought that MP3 was virtually perfect. Gee, I was also told the same thing about CD audio. '-)
When you just have finished the last mix of your last record, and listen to the first test sample of the disc burning, in the mastering room, you can just cry.
Your beloved tune had been equalized, peak limited (often with digital equipment) , and what you hear, in the middle of this ugly friction noise and the first clics of the dust is a pain you know where. With the coloration's gift of the PU head (no one sound the same).
Even a deaf person can hear instant the degradation. No need of blind tests.
While the CD copy is near perfect, and you have to listen VERY carefully to find so subtle differences your not absolutely sure...
And this digital master can be copied on various supports without ANY changes or deteriorations.
May-be you don't like combustion engines, and humanity is on the way to find better ways to produce horse power, may-be you are nostalgic of steam, or horses, but that was the best we we could do... for the time.
I know vinyls are hype, those last years, i let nostalgia to the museum and audiophile maniacs to their illusions.
I remember those nice analog multi tracks recorders. You had to demagnetize the heads all 4 hours (if you were serious) .You had to tune the HF polarization of the 24 tracks each morning (if you where serious). Your nice drums tracks, slowly deteriorate themselves at each passage in front of the magnetic heads, during hundreds of re-recordings and mixing hours. So you where obliged to equalize them during the mix in attempt to try to recover a little of their original dynamic !!!!
You had to carry a calibration tape all along with your master tape, to be sure the mastering machine was correctly calibrated (not often perfect) and fight with the guy pretending (of course) his machines are perfect !!!
And even if you don't used them and stocked the original tapes in the most perfect place you can find, there is not much left on them, 40 years later !!!! And a lot of copy of each tape turn (coil ?) on the previous and next one.
My Lord, thanks to evil digital. And thanks to USB keys
Mine are in my living room (A Nakamichi cassette desk and a modified 38/76 ( 15/30 ) Revox). But i had sell my Ampex ATR 100 machine.
Read my lips, i never said a word about the way they 'sound'. I talked about their 'transparency'. I had, some times, used my ATR100 as a post processing machine, to distord some of my digital productions in an agreeable and nostalgic way.
Painting vs photography.
I have relatively few analog tapes left since the firestorm in 1991, but I do have a number of analog alignment tapes, and a few pre-recorded tapes that Enid Lumley sold to me, when she dismantled her hi fi about 25 years ago. I will try to listen to them, sooner or later. My biggest headache is software, I lost many, many hours in the fire.
I do have a Nak, but I prefer 15ips/1/2tr minimum, if possible.
Of course, 30ips full track is even better. I wonder how Dave Wilson's tape library is holding up? I bet, pretty well.
So, you can buy fresh ones and compare with your oldest (we used to replace our alignment tapes all the years). You will find what i tell and you seem to do not believe.but I do have a number of analog alignment tapes,
Drop outs, losses of level, specially at trebles. And, if you have some square waves, diminution of slew-rate. And you will hear and see pre and post echo.
You will constat too the losses of level is not linear, more level, more losses: direct impact on dynamic.
Knowing-you will prevent him from the common law ?I wonder how Dave Wilson's tape library is holding up? I bet, pretty well.
May-i send-you some of my master tapes for you practice a laying on of hands ?
To be honest, the problems with magnetic tapes is not correlated with analog-digital: Old DAT cassetes are just impossible to read, or the error diode act as a power-on indicator.
We had several years ago to save in emergency all our sound library from DAT to HDD or magneto optic disks.
- Member Areas
- The Lounge
