The HALF-WAY House ...er...Speaker
At this point I'm looking for some philosophical advise.
This has to do with the underlying philosophy of Half-Way system, as in 2.5-way, 3.5-way speakers.
Here is a hypothetical speaker that I am thinking of building.
Start with an 8" 3-way bookshelf speaker. Then under that in a separate box put a 10" bass driver. Now, I'm trying to create a 3.5-way system, not a 4-way. And the 10" driver is a standard woofer, not a subwoofer. The whole setup will be driven by a single stereo amp.
In all the Half-Way designs I see, the Half-way speaker is always the same size as the woofer, if not the same speaker. But is that necessary?
For example, since the main speakers has an 8" bass driver, the half-way systems I see would compliment that with another 8" bass driver, but why? Why not 8"+10" or 8"+12".
Now admittedly this potential speaker build is intended to be on the bass heavy side, though reasonably so. I still want a clear balanced speakers, just with a trace more dominant bass.
So, I'm looking for an overview of Half-Way systems and the logic to choosing specific speakers, and how ridged is that? I see what is commonly done, but why is it commonly done that way?
Steve/bluewizard
It's quite common to see bunch of drivers stacked on the baffle.
Something such WMTMW or woofer woofer woofer :p
Also to use multiple subs which is not a philosophy but a way
to take control of room modes ( as they are 'activated' by different located sources ).
Such a design you describe exists , it can be done with common woofers such as Dayton classic 10" woofer,one in a separate box at the bottom and one at the top. The central unit should carry no bigger cone than a 5" :eek::rolleyes:
as it's supposed to work over 2-300 Hz.
The Center Unit, by that you mean the midrange?
The Key here is that the 10" in a separate cabinet will not match (in terms of size) the 8" woofer in the upper cabinet.
Using Dayton Classic as an example. The Classic 8" has a Sensitivity of 88dB. The Classic 10" have a Sensitivity of 89dB, and based on Dayton specs, the 10" has a 62% larger surface area.
In the 3-way section, keep in mind the plan is all in my mind at this point, I'm thinking of something in the traditional 700hz/5khz or 800hz/5khz range. Though given the midrange I plan to use 500/4000hz is possible too. Then cross the 10" at something like 150hz (give or take).
I realize anything can be done. But I'm interested in the general design philosophy around Half-Way designs. It occurred to me after I posted, that some Half-Way design are a way to compensate for Baffle Step. Below the Baffle Step, the volume drops -3dB, and adding a second identical bass driver boosts the bass by +3dB. So, you have smooth bass to much deeper values.
When the time comes, I will give some consideration to Baffle Step in choosing my low bass crossover frequency. But in the early stages, I'm simply concerned about the repercussions of implementing the Half-Way with a low-bass driver that is 62% larger than the main Mid-Bass driver.
I'm looking for a bit of extra bass, but not droning dance club bass, I still want clarity top to bottom, within my budget, but with a hint of extra bass.
Plus I feel the 10" will go deeper than the 8". I would like to take it down to at least 30hz. In this case I can skimp slightly on the size of the 8" cabinet and lose a small degree of bass, then make up for that with a substantially larger 10" cabinet.
Right now my thoughts are either Dayton Classic or Dayton Reference, depending on the actual budget. 10" low-bass, 8" mid-bass, 3" or 4" full range for the Midrange, and one of many standard 1" tweeters.
But at this point, I'm concerned as to why all Half-Way systems I see all use the same size Low-Bass and Mid-Bass, and what the negative (and Positive) repercussions are of implementing a Half-Way system with an 8" and a 10"?
Steve/bluewizard
6L6
Moderator
Joined 2010
And to clarify, you are planning on running the 8" with no high-pass? I.E., from it's low-end roll-off to the woofer/midrange xover?
With a 150hz cross on the 10", you are describing a subwoofer.
The size is not important. The impedance is.
No, amplitude drops 6db with no boundaries. In room it doesn't. Probably more like 3db. Adding a second woofer and putting a capacitor on it will double sensitivity of that woofer plus the other woofer producing the same signal, that's 6db.
You are going to have way too much bass, when you consider the added sensitivity of the larger driver, the extra 3db and room gain.
I'm looking for a bit of extra bass, but not droning dance club bass, I still want clarity top to bottom, but with a hint of extra bass.
The best thing to do is find a larger driver with about 3db less sensitivity.
Probably to keep the baffle thin.
6L6
Moderator
Joined 2010
Answering this question specifically -
A. They can use the same driver for the BSC woofer, and that saves money.
B. With a row of say, 6" drivers, the baffle can be kept narrow. Wide speakers don't sell.
C. There are some designs with a bigger BSC woofer, but they are usually side-firing.
Like this -
High Pass? No, the upper box is a standard 3-way. The 8" goes from zero to 500hz, the midrange goes from 500 to 4000hz, and the tweeter goes from 4000 to infinity (OK, not infinity, 20khz).
The 10" will run in parallel with the 8" up to about 150hz, making it a Half-Way since it doesn't have its own frequency range.
All the drivers will be passive, no active amps or crossovers.
When I said the 10" would not be a subwoofer, what I meant was not a driver classified as a subwoofer driver. Rather a standard woofer. You can functionally classify it any way you want, but the driver I buy will be a woofer.
Configuring the speaker this way probably means the system will be 4 ohms between 30hz and 150hz, but I think I can live with that. Though I might be able to use a Dual Voice Coil driver for a total of 16 ohms, which would mean a final impedance of 5.3 ohms which is some help.
An alternate configuration, would be an MTM upper section, covering midrange and tweeter, then just use a single 10" bass driver in a separate box.
If I use two 4" full range speakers for Midrange (4 ohms wired in series), I should still be able to cross relatively low. Perhaps 500hz/4khz. Though, I could cross even lower as the Full Range 4" go down to 100hz.
In my mind, I see the upper section as a somewhat standard rectangular box, but I envision the bottom section in the shape of a trapezoid; Wide at the bottom with perhaps room for front ports, and tapering as it rises to meet the Upper Section. Though I don't imagine it could be tapered enough to match the size of the upper section.
I prefer the 3.5-way over the 3-way, but perhaps the Half-Way aspect in this situation is too complicated. Still, when the time comes, 3.5-way is going to be high on the list.
Thanks for the responses so far. I realize my questions are somewhat vague, but I need to start somewhere.
Steve/bluewizard
re: "that some Half-Way design are a way to compensate for Baffle Step' - all .5 way designs are, so the xover freq to the .5 way driver should be the baffle step freq
re"Then cross the 10" at something like 150hz " - that's turning it into a 3 way + sub system , unless you have a very wide baffle... (or are just a bass freak...;))
re:"why all Half-Way systems I see all use the same size Low-Bass and Mid-Bass" - it's just easier to match sensitivity & xovers that way, but you can use different drivers...
Though I think people got it, conceptually, the 10" might be consider a Subwoofer, the point I was making was that it was not going to be a driver designated by the manufacturer as a "subwoofer", but rather a woofer.
This -
Dayton Audio DC250-8 10" Classic Woofer 295-315
not this -
Dayton Audio DCS255-4 10" Classic Subwoofer 4 Ohm 295-202
The Dayton woofer is 8 ohms, always a plus, and is rated down to 25hz, which means functionally I should be able to squeeze 30-something hz out of it.
I can except functionally that people consider it a subwoofer. Though most often a subwoofer has its own dedicated frequency range. Thought that depend, in a AV System, whether you have set the front speakers to Large or Small. In my case, I'm dealing with a Stereo system.
Attaches is a Image, crude as it may be, of the design concepts. I debate whether to make the Top Section of the 3.5-way a standard rectangular box, or whether to taper it like the Lower Section.
Again, this is all in the early planning stage. The idea is primarily built around the concept of a trapezoidal Shaped Low_Bass re-enforcing an 8" 3-way system.
Steve/bluewizard
Using the 2.5" x 2.5" grid on the drawing, we can arrive at the approximate dimensions. Though the practicalities of actually building them are very like to modify those dimensions.
Low Bass (trapezoid) -
15" wide on the bottom
10" wide on the top
17.5" high
?? depth unknown at this point...
3-Way (assume tapered box) -
10" wide at the bottom
5" wide at the top
22.5" high
?? depth not known at this time...
Complete system -
Overall height = 40"
I'm OK with 40" high. My current speakers are 44" including the Spikes.
As I thought about it, I think part of the goal of using an 8" and 10" is to somewhat approximate a 12" or 15" speaker while still keeping the bulk down.
Having grown up when dinosaurs roamed the earth, an 8" or even two 8" bass drivers still seem very small to me. Back in the day, you would be embarrassed to tell someone you had 8" speakers, though today that would be considered large.
So my mind was trying to conceive of a compromise between massive 12" and 15", yet still provide very solid bass, and while providing solid weighty bass, not compromise on the clarity of the Mids (especially) and Highs.
I generally find as the bass rises, the Midrange falls (in terms of quality and clarity).
Am I on the right track here, or have I completely fallen off the beam?
Steve/bluewizard
You might consider the the 2nd large woofer to extend the low end of your system by letting it go down to say 30 hz in a larger cab and high up untill the baffle step frequency to compensate for the baffle step at say 400-500 Hz depending on baffle width (say 10"). The room gain can boost the low end by 3-6db and give overall flat freq response. The dayton 10" HF "subwoofer" can almost do 500 Hz and go down to the abyss in a smallish cab.
Ok Soundaatam, I got the last part of your post, but the first part baffled me (no pun). A good thought on the Dayton 10" sub, but I find most Subs are 4 ohms, and I'm not planning to use a Sub Plate amp on this. It, as it stands now, a purely passive speaker. Plus, I don't really feel I need Sub-Sonic capability. Like I said, if I can get a clean 30hz, I'm a happy camper, especially if that is 30hz at -3dB. My current commercial/consumer speakers are 28hz at -6db, so one assumes they are about 35hz at -3dB. They sound good, but I would like to go just a bit deeper than that. With 30hz@-3db, that would take me down to about 25hz at -6db. That would be plenty.
I suspect centered on the 10" bass driver, that narrowest workable cabinet width would be about 13"; 1.5" on each side of the Driver to allow for cabinet width and internal braces.
As to the width at the 8" speaker, the drawing shows 10" but again, probably more like 11". Again 3/4" for the wood on the side, and 3/4" for the internal braces. That's not etched in stone, there can be some overlap between the 8" and 10" driver and the internal bracing. That's just something to fasten the fronts to.
The Dayton Classic 8" requires a 7.21 inch (183mm) opening and the Dayton Classic 10" requires a 9.22" (234mm) opening. As long as I have internal clearance for those, I should be fine.
I'm under the impression that the Baffle Step is related to the width of the cabinet in the area of the Bass driver. And one assume a narrower cabinet is a higher Step Frequency. Though I don't know how to calculate that.
If I assume this formula is correct -
f3 = 380 / WB (where WB is the baffle width in feet)
The F3 for an 11" cabinet width is 380/ 0.9167 = 415hz
Which to some extent blows my design concept. Especially if I am using the various crossover frequencies I suggested. If I use 500hz/4000hz, I might just as well run both speakers in parallel up to 500hz.
If I run the same calculation on the 10" driver, I get a step frequency of 350hz. Again, unless I'm misunderstanding, that somewhat blows my design concept.
Still, I do like the design concept, I'm just now at a loss of how to correctly implement it?
I guess, it we assume the numbers are right, then the WMTM would be workable. Use crossovers of 400hz to the two 4" full range, and a Mid to High crossover of about 3200hz.
It seems I need to give this a lot more thought.
Steve/bluewizard
May I ask why the 2.5 way is indispensable....a FAST design with a 3-4" FR driver(like the fountek 88EX or so many other ones) allows a low crossover around 300Hz where no BSC is needed as frequencies are omnidirectional. And you can have a more simple design with so fewer passive components.
2.5-Way design? Indispensable? Can you expand on that?.
Again, I'm working within a design concept, and the concept is based on a vision of the speakers I would like to see. But what looks good in my mind or my fantasies, doesn't necessarily work in reality. And that's partly what I'm trying to resolve.
That would be the speakers on the left in the graphic I included -
That just seems a cool looking speaker. But cool does not = practical.
The speakers on the Right, still looks cool and is more practical, but it is more of a 3-way design than a 2.5-way.
The goal is good bass weight without drone. Clear clean midrange, which is important to me. I think Clear Midrange is best achieved by isolating the Midrange to a midrange speaker, hence a 3-way.
Upon looking at a variety of drivers, I find it hard to get a good blend between the low and the high in a 2-way system. If I want low-bass, then I lose midrange, and struggle to find tweeters that go low enough. If I sacrifice bass, I can gain in the midrange and better match the tweeters, but, of course, I lose bass.
This is especially true when using larger bass drivers. I could probably make this work easily if I were willing to accept 5" to 6.5" bass drivers. But in my mind, an 8" bass driver is small. Which is why I have selected a 10". I would like to have a 12" bass driver, and I do have 12" 3-way DIY, but they are big and bulky, and they weigh 50 pounds each.
So, I'm trying to come up with a concept that look cool, and sounds good. Something other than common as toast tower speaker. So, in my imagination, I came up with the 3.5-way design. Which in the ideal configuration would consist of a lower trapezoidal-ish cabinet plus and upper tapered trapezoidal-ish cabinet.
Even in my crude drawing, you have to admit it looks kind of cool.
But how to make it work.
Let me use this example to illlustrate a design concept. The link below is to the Wharfedale Diamond 9.6 (I have a pair) -
Product - Products - Wharfedale Hi-Fi
Twin 8" bass drivers (truncated frames) in a 3.5-way configuration. The cabinet width is 8.25", very skinny. Yet the crossovers are at 150hz between the upper and lower bass drivers. 1khz crosses the mid-bass to the 2" dome midrange, then the Midrange to tweeter crosses over at 6khz.
The Low-Bass (Half-Way) and the Mid-Bass are the same size, both with truncated frames, but they are not identical drivers.
*** Note to Mods. This is my image, I own it, so I feel justified in using this link.
Notice the Mid-Bass has a Bullet in the middle, the Low Bass has a smooth inverted dome.
I don't believe that a 8.25" wide baffle face yields a Baffle Step Frequency of 150hz. So, there is obviously something I'm missing. In fact, I calculate a Step Frequency of 536hz.
These are very smooth sounding speakers, some would say a bit laid back, but excellent for music. A bit lean in the Midrange for videos though.
So, obviously the Low-Bass driver is not correcting for Baffle Step.
My original model of the 3.5-way projected possible crossovers at 150hz, 500hz, and 4000hz.
I also admit that I was somewhat influenced by this speaker design -
99W10.17P
The image at the top keeps changing, if you wait long enough you will see an image of that large bass unit, with this speaker on top -
93.23 (93 WMT)
You an see another photo here, though it is a bit small -
http://shop.xtz.se/images/P_6073_2_338-170.jpg
So, from this came the concept of Trapezoidal speakers, with a modest sized speaker sitting on top of a large Bass Driver in a separate cabinet.
All this combined in my mind, got shaken and stirred, and out popped the concept shown in my drawing on the Left. I still think it is a cool concept, it is just a matter of working out the details.
Obviously there is something I'm missing though.
Steve/bluewizard
Hello Steve,
So far as I can tell, that warfdale speaker is a traditional 4-way, and does not implement a .5 way, and for good reason...
Typically speaking you do not want different drivers with different characteristics sharing the same frequency range, except very low frequency ranges where we can live with far higher levels of distortion and are often trying to flatten out in-room response. Your desired implementation of a 0.5 way is not a good use of expensive crossover parts or the drivers themselves...
If you ran the 10" up high enough to cover step loss, then you'd have 2 different drivers with different characteristics sharing the lower mid-range, a good recipe for added distortion. (keep in mind, you have different motors moving different piston sizes of different weights. The summation of the 2 different drivers through the mid-range will undoubtedly have a higher resulting distortion than either driver through the same range played independently).
Also, if you run the 8" and 10" in the same system (not amplified independently), then the system will always be dynamically limited to whichever driver is the holdup for a given frequency. For example... If the 8" runs out of respectable linearity at 60hz at 16V, but the 10" has headroom at 60hz up to say, 24V, then you are forced to run both at the 16V limit in this case because they are sharing the same source. This IMO, is not desirable situation to be in as the benefit of the larger low frequency driver can not be exploited, so why bother in the first place?
To sum up... a 0.5 way doesn't jive well with the aesthetic arrangements of drivers that you are after when all powered from the same amp (whether you low pass the 10" below 150hz or run it up to cover step loss, either approach is undesirable here). I think you should be after a traditional 3 way approach here (I'd skip on a 4-way unless you have a very specific reasoning for it). Pic your 10" based on what sort of trad-offs you can live with in terms of efficiency/extension/output and work from there.
How much clean amplification will you have available with that single stereo amp?
Eric
You can use different drivers for a 0.5 way arrangement but
you need to do careful modelling to make sure one driver is
not compromising the other. Usually you arrange the lower
0.5 unit to run out of juice before the driver running into the
midrange, this is the idea behind a vented lower, sealed upper.
Making the 0.5 way driver bigger is problematic without some
skillful manipulation of two different bass alignments in parallel.
rgds, sreten.
