Interesting, they measured the response curve on a simulated loudspeaker. It shows what we knew. That the influence of the impedance curve of the load on the amp response curve, due to his internal impedance. (I know the range is ridiculously low) The resistance of the wire increase this effect, and that explain why some can spend hours and half of the budget of the year to compare loudspeaker's cables.
We are able to 'feel' very little changes in response curves when a large spectrum is affected.
We can conclude that all reviews about this passionating subject of cables are just jokes, because this cable, supposed to carry more trebles on this loudspeaker, will carry more medium on this other.
Comparing a red Ferrari with a white "vector" stripe to a black Gran Torino, they conclude that red color is faster than the black one.
Thus, audiophiles will buy red Hondas (car of the year) with a white "vector" stripe and be ridiculous in all circumstances.
Joined 2002
Please, can some millionaire having access to AES papers, enlighten-us, poor death heretics about values of measured distortions in resistances?
Carbon, carbon film, cermet, metal oxide, metal film, wired wound ?
I'm interested, because i tried to add some nice H2 to a guitar amp, using carbon ones, and it was difficult to achieve an audible result. Needed very high voltage and signal voltage, and to heat the animals a lot.
Christophe,
Aren't we really talking about 2nd order distortion in a guitar amplifier? I would think that you would be very capable of causing this on purpose if that is what you are after? Aren't we just driving a tube stage into distortion producing those 2nd order harmonic distortion products? And cheap loudspeakers that have lots of distortion or cone cry wouldn't hurt.
Christophe,
Don't they calls those fire bottles. Nothing like a tube stage in a guitar amp.......
It was, *of course* a full tube amp. Can-we talk of something else for a guitar :confused:
A vintage VOX AC30. For a fantastic guitarist, (a mix between Larry Carlton for the composition and virtuosity, Jeff Baxter for the groove and Clapton for the lyrism), a very old friend of mine, owning lot of legendary amps and guitars.
He owns some Mesa Boogie too, they are very clean, and wanted me to clean the Vox from hum and hiss, while keeping the genuine sound, of course.
This Guy owns one of the first Gibson 335 which can make you cry when he plays the blues...
Able to travel the US from est to west, to find HIS Stratocaster.
He builds some guitars from plain wood as well.
He is a genius, he lives in misery, of course.
Joined 2002
For the smooth distortion of a loudspeaker (monotonically decreasing amplitude) compute backwards how much the thirds would be at -90dB 30ths. Even at -6dB each you get +90dB or so, I guess you might worry about that first.
Scott
Your calculation for this particular case is correct.
But the point is that even if the 3rd is only –30db down from the fundamental, one might need to worry, or one might not.
Critical band masking effectiveness depends on the stimulus.
At low freq and high signal amplitudes we should not care for 3rd at –30db.
At high freq and low signal amplitude we should have to worry for 3rd or 5th at –90, -100db.
Online reading of BS 1387
BS Series = Broadcasting service (sound) pdf free download
http://www-mmsp.ece.mcgill.ca/documents/reports/2002/KabalR2002v2.pdf
George
Repeat the test with a correlated distorted copy of the original and you'll be surprised.
Have you done this?
Has anyone done this?
Listening is perhaps the most important test we put our gear through. It's sad that so few people bother to conduct Listening Tests properly. :mad:
I'll post some comments about the planned Listening Tests on Blowtorch in a bit. If we are lucky, this might become real. It's official. Pigs have been known to fly.
I love the term, "Rub & Buzz distortion" ... one of the cheap speakers in my system actually suffers from this when cold, at one stage I was fooling around a bit with the MATT track for assessing speakers and this made it obvious. The interesting thing is that driving the speaker hard effectively "lubricates" the problem area, you can hear this distortion steadily disappearing as the suspension or whatever warms up.
I wonder whether other speaker drivers behave the same way ...??
Frank
