I question your ability to hear those differences you were talking about considering your Samsung speakers as shown in your You tube videos. I would consider purchasing a set of speakers before you worry about differences between a Hammond transformer and an Edcor.
In some projects I use output transformers made here in Brazil, too.
I made the transformer project and the factory make for me.
This transformers have a good quality.
Brazil export iron M6 to USA and europe.
Here have some of best magnetic irons of the world.
Have a Tessin factory here for produce the M6 lamination, C cores and others cores.
But you do not know, probabily...
Hi Aldovan,
I have a beautiful set (matched quad) of US made "big bottle" (ST shape) GE 6Y6G
The spec sheet says clearly: max 120V on G2 and 200V on the plate.
Now you're using 270V on the plate in triode mode, ... there is not red plate, or something get stressed? Are the design center specs a bit too conservative?
J.
J.
I did not know that. Thanks for the info!But you do not know, probabily...
Hi Aldovan,
J.
Yes, the design of this tubes is conservative.
The 12W6GT and 6W6GT support 15W in the plates without red spot in the plate.
I use this tubes with 285V without problem.
And I never use a resistor between the G2 and plate and never burn the G2.
This tubes are robust, are used in vertical deflection amplifier in the old TVs.
This tube support plate peaks of 1200V in triode mode and 195mA peak in cathode current !!!
15W in plate is very soft for this tubes....
But the 6Y6 I never use in this stressed mode.
Probabily support 220 to 250V, but is fine use a 100 ohms resistor between plate and G2.
Aldovan
Aldovan
Joined 2009
[...]The hammond 125 is very bad in frequency response...
I'm surprised to hear this, as I've not seen anybody else complain about the frequency response, the 125E seems to be a good size for bass response for very little $.
the 6J9P is a good sounding tube and very quiet too.......and very cheap....
Also 6J5P is cheap as dirt, and will sound nice in this amp.
tried to look at a 6j5p aka 6AH6 specsheet, and guess where I landed
Let me guess, diyaudio.com?
The Hammond 125E have a frequency response of 150Hz to 15KHz, very bad for HIFI uses...
See in the datasheet: Hammond Mfg. - Universal Tube Output - Push-Pull Transformers - (125 Series)
The Edcor have a best frequency response...but if you can to buy a Lundhal or Tango...
Aldovan
Tony,
The point I was trying to make is you cannot tell very much about speaker response the lack of detail or any improvements to a circuit when you listening to speakers mounted in a cardboard box.
Aldovan,
Are you talking this transformer?
GXSE10-8-2.5K
10W, single ended tube output transformer for 2.5K Ohms to 8 Ohms.
I have not used this transformer but I do have on hand two Hammond 125ESE's still new and in the box. If I'm going to build this little amplifier I will not depend on it to try to reproduce low frequencies. I will instead hook up a simple little subwoofer. This is why the Hammond 125ESE transformers I have will work fine. They are somewhat limited in their low frequency response and this will mate up fine with a small subwoofer with the frequency at a maximum of 80-100HZ @ 24db crossover.
Aldovan,
GXSE10-8-2.5K
But a sub is for lower frequency...
If you use rhis Hammond transformer you have limited low and high frequency, too.
I use the Edcor GXSE10-8-8k, because the 47 need a 8k transformer.
In some projects I use transformers made in Brazil.
I make the electromagnetic project and a friend make in your factory.
Normally I use big cores for best quality.
My friend use paper isolation and GAP.
I make the GAP adjust with the transformer in the circuit.
Here in Brazil have good core production with iron GO or GNO.
Aldovan
Aldovan
Hammond cheap OT's do just fine with even the lowest bass reproduction if you stay under 50% of max rated current. For example the DSE is rated 70mA if memory serves me, and I've found it to have perfectly flat bass reproduction with 25 ... 27 mA bias (for example 71A).
Go parafeed, and you have absolutely no worries even with the smaller cheap Hammonds.
If cost is the main issue, for a cheap amp, I'd definitely go parafeed. A cheap but superb russian parafeed cap is a LOT cheaper than a half-decent OT. So just use a small cheap Hammond and go parafeed, that would be my advice.
Face the bitter truth Aldovan,
You have absolutely no idea how to construct a budget amp. Suggest you take up basket weaving and leave it to the experts .
I do not understand what you mean by that.
I'm just suggesting a good and inexpensive project. But if you prefer an more expensive project, I suggest that my finished project:
3C24 SE class A2 amplifier (red plates) - YouTube
This sound a lot good, but I lost a big time for obtain good driver for the 3C24 in class A2.
The best results for me is with transistors as drivers.
Aldovan
I think he was just kidding.
Me like the red plates! Big time!
Probabily yes !
Thanks, the red plates is show !
Aldovan
I WAS kidding - Australian humour sometimes doesn't travel wellI think he was just kidding
- Tubes / Valves
- Super cheap triode amplifier
