Hornresp
Hi, David!
Hi Alexander,
That is very strange - normally I get a Postmaster message back advising me if an e-mail I send is not delivered successfully. I had "replied" to the question you asked, so my response should have gone direct to your 'rambler' address. I make a point of answering every e-mail I receive from Hornresp users - even when I know my reply may not be what they were hoping to hear :).
Rambler works very bad last time :( But no matter.
It is highly unlikely that Hornresp will ever allow acoustic filling in the horn. While it might be okay for transmission line type speakers, as far as I am concerned it has no place in a well-designed horn system - artificially introducing a loss in the acoustic path seems to defeat the whole purpose of the exercise :).
Kind regards,
David
Of course I speak about transmission lines and hybrid loudspeakers. Right designed horns don't need to be filled - It's true!
Hornresp very well and exact calculates the TL's! For full happiness missing only two things - ability to simulate offset port and losses by filling in channel of transmission (labirynth).
Thank you for replies! Alexander.
Will it be possible in future to simulate compaund horn and BReflex with LeCleach flare front horn?
Hi Charcoal,
The way that Hornresp has evolved, a massive amount of work would now be required to modify the program to allow other than a parabolic, conical or exponential flare to be specified for the second or front horn in a compound horn design. Unfortunately I am not in a position to undertake such a large re-build of the software.
Kind regards,
David
Hi David,
I just ran into a small problem with the response display in the Wizard v. the SPL screen:
Hi Mark,
I'm talking about the big spikes around 50-65Hz in the Wizard v. the small blips around 60Hz in the SPL screen. In this particular case it doesn't matter much, but, I thought David would like to see this.
I think both displays should be the same (how do I change the horizontal scale?).
Hi Oliver,
Many thanks for this feedback, you have found a bug. It may take me a day or so to track down and fix :).
(Note that double-clicking on the "Frequency (hertz)" label at the bottom of a wizard chart will toggle the frequency range between 10-2000Hz and 100-20000Hz).
Kind regards,
David
Posts #2955/2956
Hi David,
Thanks for looking into this.
Also, I agree with Mark: being able to scale the graphs would be great. For working with subwoofer enclosures I really don't quite care what's going on above 1kHz in just about all graphs, so maybe a bass/fullrange toggle would be helpful?
Thanks again,
Would it be possible to make the frequency graph scalable?
Hi Mark,
The way that Hornresp is structured, it would now require a lot of work to add user-scalable frequency ranges to the charts. Sorry, but it's not going to happen :).
It is of course possible to export the Hornresp chart data, dump it into an existing Excel spreadsheet set up as a template, and adjust the frequency range as required. This can be done reasonably quickly.
Kind regards,
David
Hi Oliver,
I have found the problem - it will be fixed in the next release.
I am currently working on another change to Hornresp, so it may be a few days before the new version becomes available.
If you are connected to the Internet when Hornresp is started, you will be automatically advised of the update.
Kind regards,
David
