Paradise Builders
I have now tested the shuntregs on both of my boards, and it works as a charm, light in all leds, and +/- 18,05v on outputs:up: It is running a little hot for my taste though, with a supply of +/- 31,5v from a simple prereg. Hope it will help to drop 2-3v in the final c-r-c setup.:)
I have now connected the amp part of the boards, and both inputs are easily adjusted to 0v +/- 0,5mv with 10ko and absolute 0 with the 100ohm that is supposed to be there finally; but both outputs are running havoc, constantly shifting value with everything in between +/-50mv. Is this normal, or should something be done about it? And in that case what?:)
I had initially 40mV output offset. That stabilizes after some hours. I think it is the leakage of the electrolytics. They have to "form" and then the leakage goes away.
If there is still too much offset after some hours you can read in Heseners building guide how to give the servo more "authority". There is also a way to trim the initial offset of the buffer. Measure before and after the buffer if there is any big difference.
I have measured before and after the buffer, and the result is the same, so i measured with the dmm set to ac, and still the same erratic behaviour, so i think i have some oscillation:eek:
I havent installed the smd capacitors yet, so i hope that will solve the problem.
