Active vrs passive
Administrator
Joined 2004
In any case, if the overall transfer function of an active and a passive crossovered speaker is the same, they'll sound the same, and one can do either to achieve it. No magic.
Quite agree. And that's what I did with my speakers. Found the filter functions that worked best for my speakers and room via active (DSP), then built a passive implementation of that. They aren't 100% identical, but are so close as not to matter.
There's no magic in speaker engineering, just art and craft. The art is choosing the transfer function (which includes polar patterns and the way the speaker is configured to interact with the room). The craft is implementing the bits and pieces to achieve the target.
That really should be the wrap-up of this thread. It sums it all up nicely. :D
BAWP!!!!! No, sorry, that changes the alignment and the efficiency. But thanks for playing our game and we have a home version of Guess The Crossover for you, along with a year's supply of Swanson Frozen Dinners. Swanson, for when you're too busy to cook.
The right answer is: step-down transformer or autotransformer.
Using a transformer is a bad idea. If the woofer, mid and tweet all are the same nominal impedance to start with then that will get all screwed up with a transformer on the woofer. The only way to compensate for that is to give the low end current another path around the woofer. Bad idea! There goes your SPL!
The nice thing about multi-way amplification and active crossovers is that every amp gets to work at its peak performance with as little non-sound-producing power consumption as possible.
In general power amps tend to increase in distortion as they increase in power toward their own limits.
I'm surprised no one has commented on an actual example of everything I've stated in this thread.
http://www.diyaudio.com/forums/multi-way/23208-system-pictures-description-221.html#post3207732
All three sections have different SPLs and even different nominal impedances.
James. :)
