Waveguides and horns
Crossover point at about 5kHz. Active bass has adjustable crossover up to 450Hz varies.
Help needed in making a decision
A system I am working on would benefit from some input. I am following Lynn Olson's Beyond the Ariel project where he describes the LTO Apollo here:
http://www.diyaudio.com/forums/multi-way/100392-beyond-ariel-410.html#post3189501
My project will be a "poor man's" effort and favor an elliptical format for the horn. I want a smaller form factor for the horn. My crossover point will be determined. I would like any input for the relative merits to choose between the E-JMLC 600:
AutoTech E-JMLC-600 - AutoTech Waveguides - Waveguides DIY Sound Group
or the Iwata 600:
AutoTech Iwata-600 - AutoTech Horns - Horns DIY Sound Group
Lynn's description of the Azurahorn 450 should serve as a bull's eye of sorts:
"The horn is an Azurahorn AH425, which is a custom-designed (bespoke) LeCleac'h with a T ratio of 0.707 and matched for a compression driver with an exit angle of 8 degrees. The AH425 diameter is 16.5" and works best in free-air mounting with about 2 inches of separation from the top of the bass cabinet."
TIA
