Discrete Opamp Open Design
AX tech editor
Joined 2002
I'm unconvinced that amp distortion level remain at same low level.... more tones begets more harmonics from amp nonlinearities. But, an interesting thought.
From my experiments with multi-tone testing, I saw that multiple tones indeed beget more harmonics, but statistically, they do in general not fall at the same frequency where they could reinforce each other or cancel out. Which is no surprise of course. But maybe it would manifest itself as an increase in perceived noise level?
jan
There are limits on “how many tones” we can distinguish, ~640 from my Psychoacoustics book
but human perception is more limited in its resolution of multicomponent signals – only 24 critical bands are used in explaining masking phenomena
Chris Montgomery – originator of Ogg Vorbis has posted here that perceptual lossy compression uses only ~6-7 bits per critical band
over the years I have posted a few comments on distortion, perception, measurement with references, links
"Multitone Testing of Sound System Components - Some Results and Conclusions, Part 1: History and Theory" JAES V 49#11 nov 2001 by Czerwinski et al at Cerwin Vega – with 119 references it is a truly thorough and relatively recent review article of the history of distortion measurement back to the dawn of audio reproduction combined with an excellent explanation of the complexities of the general distortion representation and measurement problem with a historical review of and pointers towards distortion audibility modeling
while no complete answer to the questions surrounding distortion perception are near, the ability to reason about and discuss the subject would be advanced by a higher level of sophistication about distortion generation and measurement, you don’t need to master Volterra math to get a lot out of Czerwinski (good thing too, I’m not exactly conversant in multidimensional convolution)
I think there really is pretty good info on what constitutes CLEARLY AUDIBLE distortion - mp3 and other compression schemes are based on tossing out stuff that is perceptually masked by the music signal - a reasonable assumption is that since the presence or absence of signal in masked frequency components doesn’t matter then similar levels of distortion at the masked frequencies also won't matter – a distortion component is very likely to be audible if a good perceptual coder decides to use bits to encode it
the lesson from these perceptual models is that harmonics of a signal frequency component are likely to be masked - especially when most musical instruments produce harmonic series of their fundamentals anyway
so strictly speaking "harmonic" distortion is not very audible and THD # don't predict distortion audibility and serious audio engineers have known this from day one so much of the controversy is clouded by debates misusing a very uninformative #
engineers designing amplifiers for audio and radio have known since the beginnings of the field that intermodulation distortion components seriously degrade channel quality - intermodulation components of complex signals contain sum and difference frequency components of all of the possible orders
many harebrained theories have be proposed that sound reasonable in light of harmonic structure in music and masking but utterly fail to do the math for Intermodulation Products, it is impossible to have only “harmonic” distortion of a complex signal
there is a link between harmonic and intermod - a nth order harmonic of a single tone is evidence of a nth order distortion mechanism (some part of the system is producing a signal proportional to v**n ) - the intermod products for 2 tones acted on by a nth order nonlinearity include all possible frequencies formed by a*f1 +/- b*f2 where a,b assume all possible integer pairs that add up to n
the # of intermod frequencies increases rapidly with the order of the nonliearity causing the distortion and the # signal components, energy in the IMD products greatly exceeds the "harmonic" components at n*f1, n*f2 - for 70+ yrs engineers have explored "weighting factor" formulas to multiply the easily measured harmonic distortion components by rapidly increasing functions of n in attempts to get # that correlate somewhat with perceived quality; they largely failed to get much beyond the general conculusion that high order distortion is worse that lower oreder distortion
the current approach that appears to have some (still modest) success compares the undistorted and distorted signals’ properties after sending them through a complex model of the 1st layer of perceptual coding to account for masking of all of the distortion products, harmonic and intermod - nobody is offering absolute distortion audibility indexes, they just rank relative levels, also this is still quite poor in resolution compared to the judgments of subtleties you will find some audiophiles claiming to perceive (but just see them run when you mention abx/double bilnd testing)
at moderate levels of distortion THD is useless, presumably at Halcro’s sub ppm levels it could put a bound on the likely IMD
distortion shouldn’t be oversimplified and designers pursuing “low distortion” should really be talking about IMD with complex signals, but THD and minutiae of the “harmonic distortion structure” are likely to continue to fuel debates for some time
even the famous BBC application of the "noise power ratio"/"noise fill test" to audio distortion only gave listening result correlation for "distortion" above ~ -35 dB which is "gross distortion" by high loop gain amplifier standards
http://www.keith-snook.info/Wireles...s-World-1978/A new distortion measurement.pdf
AP High Performance Audio Analyzer & Audio Test Instruments : Downloads
presumably modern op amp design teams have at least someone familiar with:
Distortion Analysis of Analog Integrated Circuits (The Springer International Series in Engineering and Computer Science): Piet Wambacq,Willy M.C. Sansen: 9780792381860: Amazon.com: Books
diyAudio Member RIP
Joined 2005
Most expensive book I ever saw - lowest price is $ 411....
I bought that when it came out, not a bad book. I've seen OOP technical go MUCH higher than that.
The other category that gets pricey is books officially in print but of which no one has stock. And then to compound matters the data entry is sometimes done incorrectly and the misspellings make copies hard to find. Van der Ziel's books are often found with the author's name as Zeil, for example.
I have a copy of Robert Langlands' The Zeta Functions of Picard Modular Surfaces. If one searches including the author's name in the fields, nothing appears. But by title only, one outfit on Amazon has a copy of the title by "Janglands" :)
Its condition is described as "used, acceptable". The price: a mere $1979.95, not including shipping :eek: Now how long this will sit in their inventory is another story.
The harmonics of a single tone produces some 'grass' on the FFT plot. Say .01% thd worth; Can't be heard. More simultanious tones, more grass growning and IM grass, too. After 20,000 tones have been applied, that .01% THD of each of thousands of tones adds up to enough to reach audible levels. The audible effect is an equivalent increase in the background noise level. Which is described as masking details or changing character of the sound depending on music freq content played. This might be why we need Really low thd numbers on a single tone test.... to prevent the accumulated harmonics of many simultaneous tones from reaching an audible threshold. -Thx RNM
As you add more tones the power in each must be reduced or the crest factor will cause clipping. At 20k each tone would be very small and any one combination of two tones would give vanishingly small distortions (far less than .01%).
EDIT Sorry PMA already said that but let me add that in doing these multitone tests for years the results were always well behaved and for the most part could be predicted by simple IMD testing at an appropriate level.
diyAudio Member RIP
Joined 2005
Springer has a booth at every ISSCC and offer a lot of IN print books on topics related to highly specialized interests for $200-$300 or even more.
Ah for the gravy days when I would buy anything when I saw it that even remotely might be of use. I think I've bought maybe three tech titles this year so far, the most recent one Basso's latest on switchmode power supply loop compensation, which ships next month according to theory.
Since I am also running out of room, even with two 10 x 30 storage spaces, it's fairly easy to resist acquisitions that aren't very pertinent.
diyAudio Member RIP
Joined 2005
The more I read of these discussions, the more it seems that the world needs good clipping indicators on things like preamps and power amps. I intend to include them on every output of a fancy mastering EQ box I'm designing, even though it will sport stupendous overload margins.
Disabled Account
Joined 2012
jan
True enough.... it can just increase the percieved noise floor and mask fine structure... detail if anything. But, I usually look at the whole chain view.... the harmonics of each amplifier would add to the next harmonic generator/amp stage in the system. Then there are phase effects on harmonics at each end of spectrum that shifts harmonics for more or less additive (esp. with tube/transformer circuits).
Then there can be the subjective effect of all those harmonics masking and/or acting as noise in some cases. Until rigorous testing has been done on the whole of it, we can only get a few markers or clues. Clearly a single tone thru an amplifier with low harmonic levels isnt a clue to the sound of mulit-frequencies/music going thru an amp or system with many more harmonics present. Maybe 640 tones is the worst case number to use. Doesnt matter -- just need to standardize on a reasonable number (withOut the MP3 like codec justifications, pls) and then see if that correlates better to what people say they hear in the amp or system. It would certainly be a more realistic testing which might give greater insights. Thx - RNM
This is the idea.
Would it bring enough gain to keep Id of the JFets unmodulated?
But agreed, let's elaborate on this in bcarso's special thread.
Definitely also interested in this.
..and I have to apologize to RNMarsh (and other DC contributors) for my rough words earlier, I agree that DC and thermal stability must not be ignored - just had the feeling that we had put to much efforts on that, while not discussing the AC topics!
Since reading the last pages I feel more on an audiophile track again. Thanks to all for that.
I made new my schem.
This amp has good performance characteristics and rail to rail input and output.
amp works from +/-7v
Amp delivers 3 Vrms of out with thd lower then 0,001%
Pot R1 - dc offset nulling
Resistor R3 change quiescent current of the output stage.
schem:
Disabled Account
Joined 2012
No problem-o Thx for saying so. Fortunately I have pretty thick skin. Now we are friends again :) -RNMarsh
Disabled Account
Joined 2012
I would love to be more informed on distortion and masking etal. BUT does that mean we cant do anything except the same single tone or two tone Im test? Are we back to that so quickly? A lot has been studied and tested and written about. yet we keep doing single tone tests. If multi-tones aint it...Can we get suggestions for a more complete set of tests that are meaningful for our SOTA opamp being designed here? There's designing it and there is testing it. How will we know it is really better than a simpler circuit or something else? -RNmarsh
diyAudio Member RIP
Joined 2005
I'll try to get to this soon, but don't wait for me --- I will be pleased if anyone jumps in and starts it. I am easily distracted :)
I will say that after a cursory review of two patents I was kindly sent, I think that at least one aspect of linuxguru's basic approach, namely the nearly constant operating point of the main device, both current and voltage, is not covered per se.
I would love to be more informed on distortion and masking etal. BUT does that mean we cant do anything except the same single tone or two tone Im test? ...Can we get suggestions for a more complete set of tests that are meaningful for our SOTA opamp being designed here?
No need to be Manichean. Lots of good test signals out there.
The fundamental problem to me is that no-one has agreed on an actual, specific design goal. Vague target means that the conversation wanders all over the place and nothing definitive will ever come out of it.
I use dynamic measurements with very high resolution all the time. I had a lot of hope to find a correlation to audible quality. Curious enough the designs that had very low harmonic distortion measured the conventional way with single tone up to 10kHz also scored best on the dynamic tests. For example an AD797 scores great with gain up to x10 challenging my equipment. Can i build a better sounding line stage with gain of x10 compared to an AD797 with the same gain ? You bet, but why ? Added distortion that makes the sound "fuller" or more "natural" ? I do not think so, i can not hear better then -60dB, low order, and my line stage is much better at around -100dB THD.
See an old post from 2009 on my MPP thread. That was the time i measured much but i have given up.
Joined 2002
And how do you fit 20,000 different tones into the audible bandwidth and still be able to see any harmonics
Harmonics will not be seen. The idea is that noise will increase. But how this
noise will be measured in the presense of such a big population of main tones?
But new relevant methods are already proposed ;) :
When the number of tones increases, the distortion
products gradually merge into a continuum and
approach the result obtained with noise. Beyond a
certain density of tones the distortion spectrum of
multitone and noise are almost identical
With this technique we can use any complex test
signal such as music or speech at realistic levels and
measure the non-coherent distortion. Ultimately, is
this not what everyone wants to do?!
http://www.listeninc.com/PDFs/paper_121AES_non_coherent_distortion_Listen_Inc.pdf
In any case, for an amateur :D , the two or three tone tests conducted at various levels and with a real load connected at the output are still OK.
The resulting new frequencies all fall within the audio band, most of them within the ear’s most sensitive band (1-3Khz)
Two tones: The 19 kHz and 20 kHz equal-level sine waves test
Three tones: The 20.00 kHz, 10.05 kHz, and 9.00 kHz equal-level sine waves test
From Bob Cordell book, CHAPTER 22 “Distortion and Its Measurement
George
