AX tech editor
Joined 2002
> Since the independent JFET's don't share a common substrate, there's no inherent thermal balance, but .....
This one is really an old story. Doesn't time fly ....... :
http://www.diyaudio.com/forums/solid-state/135154-next-best-thing-2sk389-2sj109.html
http://www.diyaudio.com/forums/group-buys/135359-toshiba-dual-jfet-heatsink.html
Patrick
I just discovered I still have NOS of the Siliconix U441 matched pairs.
Seems very well matched, although it is a two-chip design.
Anybody used these in input stages?
jan
take two jFETs of same type -- tie the drains together. tie the sources together. A dual gate jFET?
I saw this done somewhere, i think.
A true dual gate FET has both gates modulating the same channel. There is often a front and back gate that can be tied together, or at times the back gate is tied off to the source or a carefully chosen potential. The top gate often has far less leakage and makes a useful electrometer (Ig < 20fA).
Yesterday, I got access to a new BLUE RAY player worth a good deal of money.
At least it will be an A rated product, in my favorite mags, like its predecessors from the same company. To evaluate its sonic quality level, I hooked it up to my STAX direct drive tube driven electrostatic headphones and a quality SACD recording. WOW! At least on first listen, I will know better with more sources and a longer evaluation period. That is when some 'nagging' signature might well appear.
I also evaluated its video performance in HD, and again: WOW! I didn't know what I was missing! However, normal DVD videos, were good but not that much better than any other player, AND the selection of Blue Ray videos are such 'crap' or so darn expensive, that they are almost impossible to collect, if you already have a previous collection of DVD's.
So much for the 'latest' digital technology.
The Toshibas have a slight sonic advantage over the IR parts especially in the midrange clarity. I wish it wasn't so but it is. If you want the best for audio use the Toshibas.
I assume one reason could be the awkward behaviour of the IRF P Channel parts which was pointed out by Nelson Pass and Charles Hansen.
Uh, and i'm not going to ask how you did this listening evaluation... ;)
Hi John,
Which player is it?
Disabled Account
Joined 2012
dual gate jFET -
Could you then have a jFET with input and gnfb applied to same transistor via dual gates? Simplify circuitry some more while keeping performance.
diyAudio Member RIP
Joined 2005
See the four-terminal JFETs here: Ultra-Low Noise JFETs
